175 diesel any serious problems
rieg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rieg Quote  Post ReplyReply Direct Link To This Post Topic: 175 diesel any serious problems
    Posted: 29 Sep 2017 at 9:31pm
I am thinking of buying a 175 diesel what should I be aware of, any problems that are common what should I look for when inspecting and testing? thanks in advance
rieg
Travis2766 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Travis2766 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2017 at 9:50am
The 175 is a great tractor, my dad has one and that’s what I grew up driving. He rebuilt his engine (perkins diesel) at around 7000 hours with just the normal maintenance items until that point. As with all Allis’ you want to check the hi and lo ranges and gears to make sure ithey don’t pop out. It’s not the end of the world if they do but it’s going to cost another $1000 to fix it.
190XT Series III, D17 Series IV, D15 Series II, All Crop 66, Rotobaler.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2017 at 10:28pm
A good friend of mine has one with an AC loader on it. Has been a great tractor for him. Over 5,000 hrs on it with no issues. Works well for round bales. One of his most dependable tractors.
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2017 at 7:55am
One followed me home fron an auction this summer for a small loader tractor it feals sorta clumsy.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2017 at 9:19am
The main thing to check is the transmission jumping out of gear.  Also, if it has the front pump, the linkage from the crank pulley can strip out, but that is not a hard fix.  Leaking hydraulic lines and oil on the side of the engine are common over time.  I have to agree with Victory.  Without a loader, it handles great - feels light and easy to maneuver.  Put a loader on it, the good sight lines and handling disappear.
Without a loader, it is a great field tractor.  I spent many hours on mine when I was young.  The Perkins engine is very efficient.  It's even better since I restored it 2 years ago.
rieg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rieg Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2017 at 12:30pm
Thanks guys, I have a 170 and it has never jumped out of gear I did not know that was a problem with them. What is a good way to check it? thanks again
rieg
Post Options Post Options   Thanks (0) Thanks(0)   Quote Travis2766 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2017 at 12:49pm
Driving it is the way to check, if they’re really bad 4th will pop out just driving it down the driveway, otherwise check 3rd by driving it down a hill so the ground speed catches up with the engine speed. If it stays in gear your good to go. Usually it’s 3rd gear that’s the worst.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2017 at 12:51pm
Usually 3rd gear going downhill with a load of corn behind you PUSHING the tractor is when they do it (if they do it).
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2017 at 7:15pm
Gear jumping is caused by operator abuse, not a manufacturing defect.  IF the operator ground gears shifting between forward and reverse (like when doing loader work), that's what leads to expensive problems.
