Bushhogging after soybean harvest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Topic: Bushhogging after soybean harvest
    Posted: 27 Sep 2017 at 10:37pm
I have seen several farmers out running their batwing mowers over the soybean stubble after combining . ??? Now when I was a youngin I ran the 172 over the cornstalks before plowing but why the soybean ground .Is it for tillage or for anhydrous application ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2017 at 10:52pm
they don't want the neighbors seeing all the bean stalks their green machines left uncut! saw a field yesterday, the stalks were 3-4 inches tall after harvest, and bent over, most had 1 or 2 pods still on the stalk. (brand spankin new green combine), told me that they were going to fast combining.
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2017 at 3:01am
I've seen this too!
Combine drivers as opposed to operator's,  buy it helps the wildlife
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2017 at 6:16am
I know is that if you chop up a 'left over' crop, the 'remains' will compost faster,so the good stuff gets into the ground sooner.
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2017 at 6:28am
Yes, but a soybean field should have been shaved right down to the ground.  I can't, I don't have a flex head yet...
Another possibility is the straw chopper wasn't working, or they don't have one, and they're hoping to "suck it up" and mulch it a little.
Edited by Tbone95 - 28 Sep 2017 at 6:57am
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2017 at 6:52am
When we had the K I ran the stalk chopper over the straw windrows so we could no till wheat. Now with the R52 and 62 the residue ground to nothing by the combine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2017 at 7:44am
my best combine for shaving the ground was my little "K" combine with a 13 ft head. even better than the bigger combine I have now, and it still beats the big green ones to this day that leave crop in the fields. a lot still has to do with...operators hafta slow down! i'm waiting to see the ones that planted Pioneer bean seed around here this year, as most of those plants have laid down, we'll see if the combiners slow down to get the crop in, or just go over and leave a lot of them in the fields. last Pioneer I planted went down 20 years ago, I remember combining one way, then driving back to the other end of the field and combining back that one way, took along time, but was able to get most of the crop in thru the combine! most won't take the time to do that!
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2017 at 7:53am
I remember about 25 years ago, I called a neighbor and asked him if I could go out in his bean field and re-combine it for the grain? he asked why and I told him his renter had left a lot out there after he combined it! he called me back and said have at it! and I took the "K" out there and got 2 big gravity flow wagons full of soybeans! man was that owner PO'd! then I got a call from his renter and he cussed me big time! that renter lost that ground after that! he was a big green farmer and just couldn't slow down, he knocked over a lot of beans, and that's what I went in a combined out!
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2017 at 8:00am
We roll the field after planting and run the head right on the ground at harvest. theres nothing left behind us and we use a JD 7720 with 25ft flex head. the JD will do a good job if you dont try raceing to the other end of the field. We do have to adjust the combine when ever we change crops if you leave it set for corn itll spread alot of beans out the back. the straw chopper does a real good job but its a pain to remove and install.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2017 at 8:45am
Doesn't mean much without acres of the field...
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2017 at 11:24am
Why remove the straw chopper?
caledonian View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote caledonian Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2017 at 6:52pm
It Isn't the color of the machine but the operator. Some like to slide the chopper forward to make a windrow to bale the residue. But I'll tell you this heavy bean residue can bother a anhydrous machine when its damp after being chopped & spread.
