Hydraulic hose size
rustyorange45 View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote rustyorange45 Quote  Post ReplyReply Direct Link To This Post Topic: Hydraulic hose size
    Posted: 22 Sep 2017 at 8:55pm
What is the proper size hydraulic hose to run the remote ram on an Allis Chalmers implement, 3/8" or 1/2"? Single acting cylinder ran off of a WD45. All the ports on the Allis cylinders I have are 3/8" NPT. What size were the original hoses? Thanks, Tim
1953 WD45 WF/Model 90 Loader, Oxnard Rear Blade, 80R Mower, Model 209 Disc, WD Rear Mounted Scoop, Model 184 & 160 Rotary Mowers, 1952 CA NF/L306CA mower, 1953 CA WF/Model 8 Loader.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2017 at 9:28pm
3/8 4 braded.      MACK
joe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote joe Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2017 at 2:56pm
I don't know what kind of flow those tractors had, though I would imagine it's 5~ GPM. 3/8" hose is more than big enough for even for 8GPM. 1/2" hose is way overkill. 1/2 hose is good for about 15 GPM while keeping the velocity at under 20 FPS. A lot of new equipment today comes with 1 wire hose from the OEM, and that's used with tractors that make better than 3000 PSI. A WD45 doesn't make near that, so 1 wire would work. That said you can hardly but 1 wire. Most dealers have 2 wire hose, and that's more than enough.
Edited by joe - 23 Sep 2017 at 2:58pm
KJCHRIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2017 at 5:00pm
3/8" hose with a operating PSI rating of at least 4000 PSI.
When the hydraulic ram hits full extension the pressure will spike to 3500 - 3700 PSI "IF" set correctly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2017 at 8:29pm
I would not use any thing but 4 braded hose. Pump is supposta to be 3600 psi and I have saw some spike out above 4500 psi. A busted hose at 3600 psi can do damage to the body. Be safe.   MACK
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2017 at 12:09pm
A 2 wire 3/8 100R2 or 100R16 hose is rated for 4785 psi and is more than adequate. Even a 1/2 2 wire will handle the pressure. When I make hoses I use R16 because it is more flexible than the R2.
The 4 wire 3/8 hose is rated for only 4000 psi and cost about 3 times as much as well as being stiffer.
The rating take into account any pressure spikes.
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2017 at 12:44pm
High hydraulic pressure reminds me of back in the 1970s, a community farmer put his thumb over a hydraulic cylinder's hose that had a pinhole leak. He thought by doing so would keep oil from spraying a mess. It's pressure injected his thumb & quickly filled it to 3-4 times in size. Luckily he didn't loose thumb, but it took months of draining & antibiotics to heal. Always maintain good hydraulic components.
