WD Head
Osage_Orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Osage_Orange Quote  Post ReplyReply Direct Link To This Post Topic: WD Head
    Posted: 23 Jun 2010 at 11:24am
Are all heads for WD's interchangeable?  I want to pick up a spare to rebuild in advance of overhauling the engine this fall.    I called a local salvage yard and they asked for the head casting number.  I cannot find one.  The head is 4" tall and the engine serial # is "WD350496PA".
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2010 at 1:20pm
WC's and WD's should all be the same I believe. I'm sure the WD45 head will bolt up too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Osage_Orange Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2010 at 2:07pm
I'm presuming the 45 would have longer push rods (since the head is 4-1/2" tall). If so, and I were to get them also, would the 45 match bolt holes, water passages, etc.?
Good View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Good Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2010 at 2:24pm
The push rods are the same the difference is in the rocker arm stands were it's bolted to head. You will need head bolts and studs from tall head and rocker set to use one.
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2010 at 3:44pm
I'm with "Good" on the WD45 head change, The push rods are the same in a WD and the WD45. One more thing you will need is the WD45 valve cover. Don
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2010 at 7:26pm
Osage,
Your 4" head is the same as the WD-45. The "tall" (4") head was introduced on WDs with ENGINE Ser. #WD289001. The WC and early WD "short" head is 3" tall. So.......your best bet is to buy a late WD or WD-45 head to match the one you have.
No need for different rocker stands or valve cover.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Osage_Orange Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2010 at 10:37pm
Thanks to all for the info. When it gets cooler, I'll get over the salvage yard and pick one out.
