No longer available new!
Rltool View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rltool Quote  Post ReplyReply Direct Link To This Post Topic: No longer available new!
    Posted: 15 Sep 2017 at 7:33pm
I was rebuilding the carb for my D17 & found the choke shaft was bad. Didn't want to steel it from another carb. Which would make that one unusable. Checked high & low for another. Nothing.
So, I made one!
Don't tell a machinist that something is no longer available! It is just a challenge. LOL
Ray W.
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2017 at 8:44pm
Sure looks good. You could probably sell a few of those.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2017 at 9:41pm
You are right!  I give my local machinist a ton of business and everything comes back looking as good as new.  They are well worth the price they charge.
ksbowman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ksbowman Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2017 at 10:15pm
Great job!
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2017 at 12:16am
Ray,  that loooks nice!  I'll keep that in mind for possible future reference.
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2017 at 8:27am
Good job Ray!!!
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2017 at 9:45am
Looks real good! I think Desert Joe made one of them for one of his tractors also. darrel
BrianC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2017 at 12:11pm
How did you machine the slot?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rltool Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2017 at 12:23pm
Thanks guys!
It was a little intimidating at first. But after I made a blue print of it. It didn't seem near as bad.
I will take a picture of my setup for the next one.
Brian, I used a slitting saw for the slot. Basically a small saw blade for metal. I had to make the arbor to hold it also. I will post a pic of that too.
Ray W.
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2017 at 12:33pm
Ahh.. a rotary blade. I assumed you used an end mill, but it is kind of small for that.
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2017 at 12:34pm
Looks great!
I only wish I had the knowledge and the resources to do things like that!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2017 at 1:39pm
I wouldn't expect anything less from you Ray!!
ANOTHER GREAT job and a BIG pat on the back!!
I am so proud to have met you, you are a GREAT friend!
Dipstick In View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dipstick In Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2017 at 2:21pm
I often think that if I were starting life over, I think I would love to study machining. The closest I ever came was working at Talbert Trailers, running a big drill, and power hack saw that I cut big beams with. And a twenty foot wide shear and brake to bend metal and make channels and angles!
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2017 at 8:43pm
Several D17 carb kits on ebay with the shaft included in them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rltool Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2017 at 8:48pm
Gary, I saw a lot of kits with the throttle shaft included. But didn't see any with the choke shaft also. Do you have any links to them?
Ray W.
I did find some for the smaller Marvel carbs. The ones I need are for the larger TSX-464 & TSX-773. ( 3.750" over all length )
Edited by Rltool - 16 Sep 2017 at 9:06pm
Tim NH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim NH Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2017 at 6:46am
Ray has done many projects for me thru the years. His workmanship is incredible. Last spring I bought a 7000. The alternator double groove pulley was worn bad on one of the grooves. I could not find a new one. Ray said just send me yours. When the new one came, I couldn't get over how nice it was. Making something like that takes talent. Thanks Ray, to my good friend in MI.  Tim
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2017 at 7:12am
Ray W.
I guess it was for the smaller ones and I'm sure that the ones you make are a whole lot nicer and better fit than the Chinese stuff anyway.
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2017 at 7:52am
Ray W
Could you repair a steering gear box where the parts are no longer available?
Dusty.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rltool Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2017 at 9:13am
Dusty, I have machines & sources available to do just about anything. Just a matter if cost out weighs the need.
Give me a call or pm.
(616)4three7-2527
Ray W.
I'm not sure it is all that better than the production parts Gary. But necessity is a very good motivator. LOL
Edited by Rltool - 17 Sep 2017 at 9:16am
