8070 air cond pressure switch |
Ron(AB)
Topic: 8070 air cond pressure switchPosted: 15 Sep 2017 at 2:45pm |
I'm installing a new compressor (dryer & exp valve too) and was wondering if it was normal for the compressor not to engage with the key, fan, and ac turned on?
Just want to make sure everything works before putting in the 12a.
Ron(AB)
Posted: 15 Sep 2017 at 2:47pm |
I was thinking the pressure sensor needs some charge (pressure) to ground the mag.
Is that true? |
CAL(KS)
Joined: 18 Sep 2009 Location: Chapman, KS Points: 3804 |
Posted: 15 Sep 2017 at 2:56pm |
if that system has a low pressure switch it wont engage the pump until there is enough pressure
Dad- WD, D17D, D19D, RT100A, 7020, 7080,7580, 2-8550's, 2-S77, HD15 |
Stan R
Posted: 15 Sep 2017 at 4:27pm |
What does the wiring/ wiring diagram show? Then you will know.
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8729 |
Posted: 15 Sep 2017 at 6:39pm |
low press switch up front at dryer.no clutch till some pressure or jump switch to draw in Freon(make clutch run)
wekracer
Joined: 13 Oct 2009 Location: Tebbetts, MO Points: 1590 |
Posted: 15 Sep 2017 at 7:24pm |
Did you pull a vacuum on it. The freon is under enough pressure in the tank to activate the low switch without having to jump the compressor. Just open the low valve and let it run for a minute or two.
Ron(AB)
Posted: 15 Sep 2017 at 7:35pm |
Right, I needed to jump the low pressure switch at the dryer. Thanks
Everything checks! It's been a while since I did one. |
