6 to 12 volt conversion
jmugoose View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jmugoose Quote  Post ReplyReply Direct Link To This Post Topic: 6 to 12 volt conversion
    Posted: 21 Jun 2010 at 4:48pm
I have a 54 Model G.  It was my granddaddy's and a few yrs ago he updated it to a 12 volt alternator.  He used it all the time, but it would die and he would have to charge it in the barn before using it again.  I am under the assumption that he wired it wrong.  It is currently set up as negative ground, where doing research I think that it is likely positive ground.  Am I correct, I would like some confirmation before switching and having it blow up in my face.  Thanks for any help.
Branodn
Ted in NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2010 at 5:01pm
Alternators are commonly NEGATIVE ground...However there are rare exceptions.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2010 at 5:38pm
There is no need to switch it back to pos ground and if alternator is neg ground you can't change it. If you want to change it for a restoration purpose, you will need a generator anyway. After charging the battery, put a volt meter on it . Remember what you get, should be 12v, then start the tractor up and see if you have 13 or more volts. If not the alternator isn't working for whatever reason.
safetydon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote safetydon Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2010 at 8:02pm
I have a WD, also positive ground, and a friend did the conversion to 12V for me.  He included a convertor to address the reversed polarity and it works great.  The one catch is, as he predicted, I fried the 6V starter in exactly 1 year.  My friend runs an auto repair shop and I would suspect any good mechanic can do what my friend did for the polarity.
Good Luck,
Don
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2010 at 12:49pm
Don, how did you fry your starter? I converted my CA about 14 years ago and have never touched the starter. I've always remembered that I have a 6V starter and not grind away on it if the engine doesn't want to start.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2010 at 1:54pm
There is nothing to address about changing the polarity. Switch the leads around and replace the coil if it has a distributor, and switch the leads on the Amp meter. There is nothing to "convert". My CA and WD45 have been 12v Neg ground for close to 15 years each and never had any trouble with the starter or anything else for that matter.
Edited by CTuckerNWIL - 22 Jun 2010 at 1:58pm
