8050 Pto seal
Oldred View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Oldred Quote  Post ReplyReply Direct Link To This Post Topic: 8050 Pto seal
    Posted: 21 Aug 2017 at 3:47am
How common is the Pto seal to start leaking on an 8050 ? Found some small pieces of hay wrapped behind the 540 flange after the hired man (Dad) was running discbine. Got new seals at the shop ready to go should I be worried about the bearing and have one on standby before disassembly also ?
Thx for any info/experience
Mark
Edited by Oldred - 21 Aug 2017 at 3:48am
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2017 at 7:45am
No, bearings are usually in good shape.      MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2017 at 9:04am
Two seals and one Oring.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Oldred Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2017 at 10:37pm
Cool Thx for replies.
Got them at the shop ready to go.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Oldred Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2017 at 11:31pm
Started the disassembly.
How do you get the inner bearing off the end of the pto shaft right behind the big nut to get the shaft out ? Kinda puzzled ?
Didn't want to get to ruff with it just yet ?
Thx Mark
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2017 at 6:59am
Use a slide hammer and pull shaft out of bearing.    MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Oldred Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2017 at 9:12am
Okay Thx
Post Options Post Options   Thanks (0) Thanks(0)   Quote Oldred Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2017 at 11:49am
I take to get the bearing back on just tap on pto shaft gently for installation then ?
Thx
This page was generated in 0.240 seconds.
