Wanted Perkins 4.236 Diesel engine
Johnnyboy5050 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Johnnyboy5050 Quote  Post ReplyReply Direct Link To This Post Topic: Wanted Perkins 4.236 Diesel engine
    Posted: 21 Aug 2017 at 12:31am
Looking for used or rebuilt kit 3.9l Allison charmers 715 with Perkins Diesel engine
Dipstick In View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dipstick In Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2017 at 1:10am
What's an Allison charmers????????????????
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2017 at 4:40am
noob!
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2017 at 5:51am
Must be this Wink
[TUBE]TJuE-e6SDfU[/TUBE]
Wink
I am a Russian Bot
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2017 at 6:03am
D21?  Isn't that a D51 .... errrr.. P51 tractor?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Johnnyboy5050 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2017 at 9:27pm
Yea sure that's what I misspelled I didn't think folks need to see a picture to know what I meant I'm sure you don't have what I'm looking for don't you have anything better to do 👨🏿‍🌾 farmer boy
waltw View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote waltw Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2017 at 10:02pm
I rebuilt the 248 perkins in my 175 in 2010. The machine shop I used got a rebuild kit from a company named Maxi Force.
A 248 is the same as a 236 except for bore.
I also had to get new shafts for the balancer. I got those from a company named Endurance engine. Those parts were also from Maxi Force.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2017 at 7:02am
Look around. The 236/248 was used in agriculture, industrial and marine services. The engine is available with a stamped or cast oil pan. If you're looking for a short block you should be able to mix and match with what you have.
We poke fun at A/C mispellings. It's sort of like when someone hands you a piece of paper with your name misspelled on it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Johnnyboy5050 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2017 at 7:23am
Thanks for all the pointers I appreciate your time
Johnny
orangereborn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2017 at 8:58am
Johnnyboy5050....Welcome to the forum.  Us long termers here are always glad to see new faces. If your interested in AC this is the place to be....Dale
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2017 at 12:59pm
Don't take offense. It's a long running joke. And yes at the moment I really didn't have anything better to do.
Edited by Lonn - 22 Aug 2017 at 1:00pm
Wink
I am a Russian Bot
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2017 at 1:06pm
I do believe that the 236 Perkins in the 715 TLB has heavier timing gears to drive the hydraulic pump. Check it out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2017 at 2:40pm
Here's one of several rebuild kits I found. It was as easy as Googling "Perkins rebuild kit."
This page was generated in 0.173 seconds.
