Hillside Plow
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Topic: Hillside Plow
    Posted: 21 Jun 2010 at 9:10am
I saw one of these advertised, but what is a Hillside plow?
Charlie
firebrick43 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote firebrick43 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2010 at 12:00pm
My guess is its a two way plow.  Ie it the plow either has two separate bottoms such as on a b/c or is a rollover like the later mounted allis plows. These plows were typically used in hills so you alway turned your furrow up hill.
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2010 at 1:04pm
As I understand it, a Hillside plow usually had an hydraulic adjustable bar that slide sideways to bring the plow closer or farther from furrow down on the 3pt hitch assembly.
cyclone View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cyclone Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2010 at 9:01pm
hillside plow is a team draw plow you got to the end your roll you turned your team around .you lifted up on the handles kicked a catch and the mold board and point and turned over and the catch would catch.it had no land slide.
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2010 at 8:37am
Post Options Post Options   Thanks (0) Thanks(0)   Quote cyclone Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2010 at 9:13am
thanks brain for posting the pictures its been a long time since i saw a hillside plow.as a child in eastern Kentucky.we had one it was a vulcan. I had forgot all about it.thanks again for posting the pictures.
GlenninPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenninPA Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2010 at 11:02am
My grandpa plowed with a Syracuse. We played with it as kids. It finally rusted away to nothing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2010 at 11:07am
Thats an old tyme plow. What do the modern hillside plows look like?
ToddSin NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ToddSin NY Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2010 at 11:13am
We have a 5 bottom 3 point Oliver plow that we call a hillside plow. There is a cylinder on the front that moves the plow side ways about 12-18".  This is so when you are plowing along a side hill and the plow is not up close enough to the last furrow plowed you can slide it up the hill to get the first furrow laid against the last furrow. This keeps you from having a gap in the furrows.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2010 at 2:19pm
I have a picture of an Oliver plow like that. It was in a park like area at a Mill and restaurant on the Blue Ridge Parkway.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ToddSin NY Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2010 at 3:31am
CTucker I doubt you've seen them with automatic reset bottoms though! You fellows out there in no rock land don't have a use for them like we do here in rock country!! LOL!
This page was generated in 0.043 seconds.
