Is this an 80S mower?
DakotaSteve View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DakotaSteve Quote  Post ReplyReply Direct Link To This Post Topic: Is this an 80S mower?
    Posted: 18 Aug 2017 at 11:17pm
I am trying to determine the model number of this mower. Id like to mount it on a CA. Could anyone help me out....maybe tell me what i am or am not missing?
If i am missing something and someone has what i need to get this up and mowing please message me.
Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2017 at 3:38am
Looks like a b-c mower, to me...
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2017 at 5:45am
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2017 at 5:50am
We had one like that. The two holes at the back of that mower would match to the holes in the drawbar of a C. I don't know if it could be made to fit a CA or not. I never paid any attention to what the model number was.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2017 at 6:26am
That is a #5 mower. It is distinguished by the curved mounts at the front and will have twin drive belts at the rear. It is an update of the B/C mower that became available for the CA tractors and with the proper mounting package was also for the B/C tractors. You need the proper drawbar to mount it on a CA along with the proper drive pulley.
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2017 at 7:59am
That's right.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DakotaSteve Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2017 at 8:00am
Thank you all. If someone could help me w what im missing that would be great.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DakotaSteve Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2017 at 8:02am
Im going to dig out a few brackets and post a pic of what i have that could maybe be for it. Im kind of doubtfull though.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2017 at 3:20pm
That's just like the one I have that Dad used on the CA. This CA is a pin hitch tractor with the big bail for the drawbar that connects to the lift arms.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DakotaSteve Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2017 at 3:31pm
CTucker...could ypu post a couple pics?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2017 at 11:20am
Dad never had any special brackets. It sets right on the drawbar bail of the pin hitch . I tractors. I don't have pics of the mower on this puter, but it is the same as the one above.
 Image result for CA Allis with pin hitch drawbar
Edited by CTuckerNWIL - 20 Aug 2017 at 11:28am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DakotaSteve Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2017 at 12:05pm
Ok. Yep i can see that.
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2017 at 8:17pm
The front brackets are not straight up, so it would be for a CA
ALLIS EXPRESS!
This year:
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2017 at 8:56pm
As said above it is a Number 5 mower for the B, C, CA.  The front brackets are positioned in the forward holes for the CA.  In the rearmost holes for the B-C.  You have the mower frame but would need the mounting kit for the mower.  For the CA - again from memory only - you would use one of the rams positioned forward and a tube that fits on the end of the ram to the lift arrangement that you would need also.  Closer examination of the unit shows that you may well have this lift arrangement.  Also, you would need the pulley, belt, and drawbar mounting brackets.
The B-C would use a different ram attachment and a different lift lever to fit the smaller ram of the B-C.
Perhaps someone has a manual for a number 5 mower and this information would be clearly pictured and explained.
Let us know how it goes.
Good Luck!
Bill Long
Post Options Post Options   Thanks (0) Thanks(0)   Quote DakotaSteve Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2017 at 8:59pm
Very good Bill. Thanks. I think i have the tube for the ram. I will post a pic.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2017 at 9:37pm
The double groove drive pulley also gives it away that it is for a CA.
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote DakotaSteve Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2017 at 9:44pm
If anyone has any pieces i may need laying around let me know. Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2017 at 9:53am
Eldon,  The number 5 mower used the double groove pulley for both the CA and  the B-C.  However, when the number 5 mower came out there was hardly any need for the B-C hookup.  Basically the number 5 was to fill a need for the CA.
Eldon,  Hope this finds you well.
From the East Coast to the West Coast
Good Luck!
Bill Long
Post Options Post Options   Thanks (0) Thanks(0)   Quote DakotaSteve Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2017 at 8:46pm
Ok...These are the loose items i got w the mower. If anyone can help identify that would be helpful. Also...hopefully some of these go towards mower mounting.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DakotaSteve Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2017 at 8:47pm
Picture 1
Post Options Post Options   Thanks (0) Thanks(0)   Quote DakotaSteve Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2017 at 8:48pm
Picture 2
Picture 3
Post Options Post Options   Thanks (0) Thanks(0)   Quote DakotaSteve Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2017 at 8:50pm
Picture 4
Post Options Post Options   Thanks (0) Thanks(0)   Quote DakotaSteve Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2017 at 9:24pm
Picture 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote DakotaSteve Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2017 at 9:25pm
Picture 6
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2017 at 10:34pm
http://www.allischalmers.com/forum/uploads/16988/2017-08-22_20.37.04.jpg
I think this is what my book shows as an adapter for the Snap Couple CA.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2017 at 7:43pm
The triangle item is used on the pitman rod end that connects to the sickle bar blade.  You would have a special wrench that was used to release the tension on the sickle blade ball hook up and a wide other end that would spread the pitman rod ends so the pitman rod could be removed.
You have your twin belt pulley and the mounting brackets for a Snap Coupler CA.  The other items I am not certain what they do.
I do not see the attaching bolts for the rear draw-bar.  They came with a lot of heavy washers that could be added or removed to increase tension on the drive belt.
Send us pictures when you get it hooked up.  We sold a lot of the B-C mowers.  And since the Number 3 rear mounted mower and the number 7 came out we used them on the CA.
Good Luck!
Bill Long
Best I can do from memory.
Good Luck!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DakotaSteve Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2017 at 7:55pm
Well that's great info! Thanks Bill! I need to get it slid under the tractor and go from there. I will send pictures.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2017 at 7:20pm
Steve, you don't slide the mower under the tractor. You pull up to the right side, then lock the RH brake and swing the tractor over the top of the mower. You have to pull the front tires past the rear of the mower first. Hope this is clear.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DakotaSteve Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2017 at 9:04pm
Leon that helps alot. Yep I understand.
