CA Engine Block Question...
DakotaSteve View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DakotaSteve Quote  Post ReplyReply Direct Link To This Post Topic: CA Engine Block Question...
    Posted: 18 Aug 2017 at 11:08pm
I have a late model CA with a snap coupler. My others are early CAs. I was looking at the AM numbers on the sides of them and found that my late model snap coupler CA has a different AM number on the right hand side...they all have the arrow head shaped extrusion to the right of the dipstick. I like things original... Could it be that my late model has the wrong motor?
Early CA Numbers AM 2916 33
Later CA Numbers AM 4033 1
Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2017 at 6:33am
I just went and looked at mine and it has the early CA Numbers AM 2916 3.
As far as I can see, mine only has one 3 on it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DakotaSteve Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2017 at 7:56am
Thanks Ted.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2017 at 8:17am
I've got an additional question Steve, my engine serial # has a PA after it.  I can't find anything on this?  #  CA 168xxx PA   I know it wasn't made in Pennsylvania.....What does PA stand for?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DakotaSteve Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2017 at 9:12am
Mine has a PA as well. I thought i read somewhere that meant something unique???? Might be wrong
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2017 at 10:46am
That number is a casting number. casting numbers changed every time there was a new pattern made, or at least when there was an engineering change in the casting.
 PA is a gas designation for a later model engine , probably with a bit higher compression than a GA engine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2017 at 10:51am
I hadn't heard of the AM 4033 numbers before, but they are out there. http://forums.yesterdaystractors.com/ttforum/viewtopic.php?p=3298835&sid=83ab6b03bc17cc2700ada43cb44f9adf
Post Options Post Options   Thanks (0) Thanks(0)   Quote DakotaSteve Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2017 at 3:01pm
Ok. Yes that sounds right the PA engine has higher compression. Does this mean the PA serialed Engines may be a bit snappier?
Edited by DakotaSteve - 19 Aug 2017 at 3:01pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2017 at 3:15pm
I don't know if you could notice the difference, changes weren't much I imagine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DakotaSteve Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2017 at 3:19pm
Il bet it would be a torque monster....wheelies 4 days!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DakotaSteve Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2017 at 9:16pm
So....After reading the link. Im led to believe it could be a military block.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2017 at 11:15am
There was no distinction for military blocks that I know of. I think Dick may have hit on it when he posted this. "Maybe and that is a (just maybe) a run of block castings were made as replacement parts after the last production tractors were assembled."
Edited by CTuckerNWIL - 20 Aug 2017 at 11:16am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DakotaSteve Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2017 at 12:04pm
Thanks. That may be whats going on.
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2017 at 9:44am
I don't think any 2916 block will have the casting for the fuel pump. My guess is the casting number changed when they added the material for the fuel pump.
How long was the 125 power unit still available after CA production ended ?
The last digit on the casting number is the date code.
I think 1938 was -10.
Edited by Nathan (SD) - 21 Aug 2017 at 10:19am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DakotaSteve Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2017 at 10:04am
Nathan, I have two of the 2916 blocks with the arrowhead casting extrusion by the dipstick....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2017 at 10:15am
I just found some pictures of a couple too. The date code numbers are high 20's? or 30 on those?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2017 at 8:37pm
That "date code" doesn't date the block worth a hoot. I have a 51CA with the original engine. My Dad bought the tractor new in 1951, and the "date code" says its a 1956 block, but the tractor number and engine number are BOTH early 1951.
 I have talked to other people with similar tractors.
