7000 rear hydraulic pressure |
Tim NH
Joined: 16 Oct 2012 Location: Lancaster NH Points: 1155 |
Topic: 7000 rear hydraulic pressurePosted: 14 Aug 2017 at 6:07pm |
I only have 700 lbs at idle. At 1200 rpm the gauge shows 1200 lbs. At 1800 rpm its 2250. Is this low reading at lower rpm normal. Tim
MACK
Posted: 14 Aug 2017 at 9:47pm |
Sounds about right. Where are you checking it? MACK
Tim NH
Posted: 15 Aug 2017 at 4:58am |
Right at both rear outlets. Tim
tomNE
Joined: 13 Sep 2009 Location: dorchester, ne Points: 1225 |
Posted: 15 Aug 2017 at 5:27am |
If you wanna install a loader you will need to shim the pump. good AGCO dealer will walk you thru the process. I'd call 2250lb as normal.
Hurst
Joined: 11 Sep 2009 Location: Midway, Ky Points: 1220 |
Posted: 15 Aug 2017 at 11:23am |
I'd like to hear more peoples' experience with this, as my 7000 is much like this as well. It makes it a bit annoying bc not much will operate at idle. My fords all put out full pressure with a gear pump at idle. I'm thinking my pump might be a little on the worn out side, I've adjusted the relief pressure at the remote valves to 2300 psi, but I have to be close to 2000 rpms to get that. Anyone have one with a new pump or remember from when they were new? Do these pumps turn too slow at idle to be very efficient?
Hurst Edited by Hurst - 15 Aug 2017 at 11:25am |
1979 Allis Chalmers 7000
5800 Hours |
Tim NH
Posted: 16 Aug 2017 at 6:18am |
I haven't turned mine up yet Hurst. I thought the problem was unique to just my tractor. Tim
Pete from IL
Joined: 29 Dec 2009 Location: Beecher IL. Points: 314 |
Posted: 16 Aug 2017 at 6:44am |
The pump has been rebuilt on my 7000 and still the same as yours, very low pressure and flow at low rpm.
DrAllis
Posted: 16 Aug 2017 at 7:14am |
That's the way it is. The priority valve sees to it that the power steering works good at slow speeds and as a result, the lift system isn't very good. Get over it or get a 7010 or bigger.
Hurst
Posted: 16 Aug 2017 at 6:40pm |
Did they change much between the 200 and 7000? Or do they act the same as well?
Hurst |
5800 Hours |
wayneIA
Joined: 17 Oct 2009 Location: Waverly, IA Points: 268 |
Posted: 16 Aug 2017 at 8:13pm |
My 190XT III is the same way, to get good pressure you need to rev the engine some. My D21 II will give full hydraulic pressure at an idle. I don't remember if the 200 I ran for a farmer had good pressure at an idle or not, most of its time was spent on a feed mill and not running hydraulics. The 190 doesn't do bad once you get to around 1200-1400 rpm, but for full pressure you usually need at least 1500 rpm.
DrAllis
Posted: 17 Aug 2017 at 7:18am |
Very late XT's and 200's had the same hyd pump which are similar (but not the same) as a 7000.
lentsch
Joined: 10 Feb 2011 Location: Glencoe,Mn. Points: 236 |
Posted: 17 Aug 2017 at 10:10pm |
I had to put a new pump on my 7000(black belly), now the power steering works better than it did for quite a while but the PTO disengages when I shift the power shift. Kind of annoying. Maybe your pump is getting tired?
WD,D15,190XT,7000,8010x2,7060,8070
Hurst
Posted: 18 Aug 2017 at 6:58am |
Mine also disengages when I shift the powershift sometimes, but I'm not sure my pump isn't a little tired. I think the spring in the spool can be cut down a little to help with that problem, but haven't tried it yet.
5800 Hours |
DrAllis
Posted: 18 Aug 2017 at 7:23am |
Some black belly 7000's had an occasional issue with the PTO lever jump-out and there may have been an orifice fix for it. I cut off the spring if I remember right....didn't have only 1 or 2 of those models to contend with.
Tim NH
Posted: 18 Aug 2017 at 7:48pm |
Thank you guys for the information. I was talking to a guy at the GOTO today. Who mentioned I could swap the relief valve from the traction booster, just to make sure the lift valve wasn't sticking. Tim
tbran
Joined: 14 Sep 2009 Location: Paris Tn Points: 3664 |
Posted: 20 Aug 2017 at 2:45pm |
The draft control outlet line can be tee'd into the flow to the remote/3 point - draft will now not work well but.... Adds about 3 gpm to the flow.
