Rough running D19
cnafarms View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cnafarms Quote  Post ReplyReply Direct Link To This Post Topic: Rough running D19
    Posted: 11 Aug 2017 at 5:45pm
Have a D19. Was missing a little bit so changed plugs, wires, points, condenser, cap, rotor button and coil. Gaps on points and plugs are set to specs in operators manual. Starts right up and sounds good for about 10 minutes then starts missing and spurting again. So I'm guessing next step would be to clean the carb. Any suggestions from the experts on here.
Thanks
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2017 at 5:50pm
Could have something to do with the gas part of it, but I wouldn't totally rule out the new condenser. Some are pure junk...Rick
Post Options Post Options   Thanks (0) Thanks(0)   Quote cnafarms Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2017 at 5:57pm
Well I'm not saying the points or condenser are or aren't junk. Went to Agco and got them. Made in the US so they aren't the cheap china junk.
orange-is-power View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orange-is-power Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2017 at 7:44pm
If you pull the choke out slightly does it smooth out any?
Post Options Post Options   Thanks (0) Thanks(0)   Quote cnafarms Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2017 at 7:50pm
No the choke doesn't help it at all. Tried doing that just still missing and spurting. Checked the timing with a light seems to be perfectly or at least with my eyes in time
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2017 at 8:20pm
Check the valves to make sure one of the intakes isn't too tight.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2017 at 8:26pm
Also check to see if the intake manifold is sealed to the head good.Spray a little ether where the manifold goes against the head when its running, if the engine speeds up there is a leak.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2017 at 9:25pm
I would start by going through the fuel system - clean out tank, sediment bowl, carb, gas line, then refill with FRESH gas from a station - not a barrel on the farm.
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2017 at 10:00pm
Sticky valve or valve set too tight. If it were fuel the problem would show up when the engine is cold and needs more fuel. It could be the coil, but I'd assume  you took care of that when you changed the coil. Manifold gasket could be the problem, but again I'd assume the problem would be worse when the engine is cold and the metal hasn't expanded and tightened things up.
One electrical thing you could check it the supply voltage to the coil. Check it when the engine is cold and again when hot. As Rick said, you could be dealing with another bad condenser. Replacing a bad part with a new defective part will make you scratch your heat.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2017 at 6:33am
some things to do...
remove gas tank cap and retest....
if it runs fine, cap is blocked causing a vacuum stopping gas from getting to carb
shine LED light into tank, check for crud or bugs that semi-float then block the exit port
remove sediment bowl screen, carefully clean and replace
remove gasline at carb,put 2-5 gallon bucket under it, then open petcock and let gas flow out. should be a good solid flow.FILL the bucket ! A 20 second test ain't good enough. Let bucket sit for 2-3 hrs, ANY water in the bottom ?
hmm 10 minutes.... will it restart immediatley or do you have to wait  say 10-15 minutes ? if it restarts immediately that eliminates the new coil. but check for spark anyway. Unlikely a bad ballast resistor as they tend to 'open' when they die not 'self heal'.
missing and sputtering does sound more 'gas' related than electrical.
Jay
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2017 at 8:48am
What number spark plugs are you running? I worked on a 706 gas once that acted like that. It had new plugs in it but it ran awful after a few minutes. Turns out that the Napa book says to use D21 plugs but the IH book called for the cooler D16 plugs. Slapped in D16s and the problem was solved.
A D19 should use N5 Champion or equivalent. Some of the new cross reference books are wrong and say either N8 or N9. Those are the old numbers the new equivalent numbers are different.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2017 at 9:13am
I sincerely hope you aren't running Champions in it.
Edited by DougS - 12 Aug 2017 at 9:13am
ACjack View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACjack Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2017 at 9:53am
Can't say that Champion plugs are good or bad nowadays but, did you know that they were the factory plug during the 70's.Smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote cnafarms Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2017 at 9:58am
They are the champion spark plugs N5
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2017 at 11:03am
I've found out that the D19's...all four of them that I have, run better on Champion plugs than any other plug out there. I use the N5C plugs all the time...
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2017 at 11:31am
Check the gas cap and the fuel pump, and run a compression test.
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2017 at 3:21pm
 I don't know about a D19, But I can tell you several true stories about champions in WD's,  D17 tractors and a few in chevrolet cars...  and the stories are NOT favorable to the champion plug... and were replaced with A-C plugs
This page was generated in 0.054 seconds.
