180 Transmission main shaft chewed off.
Rayhowling View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rayhowling Quote  Post ReplyReply Direct Link To This Post Topic: 180 Transmission main shaft chewed off.
    Posted: 09 Aug 2017 at 7:20pm
The transmission shaft from clutch through torque tube to rear end has the gear on the shaft chewed off. This shaft is on longer available and 3 gears are also chewed off. I have found a torque tube with every thing in it. The problem is my 180 serial #  8582 and Allis made a change at serial # 11123 and the transmission I found is serial #11783. Will this transmission work on my tractor? It is a good tractor yet and I don't want to part it out. What are my options?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2017 at 7:18am
Use the whole complete torque tube and internals and you'll be back in business.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rayhowling Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2017 at 8:24pm
Thanks DrAllis. We've purchased a torque tube with all the works in it that didn't have very many hours on it. it had a gas engine in the 180 and it blew so probably wasn't worked too hard. I will let youall know when we get it running.
