B Allis marvel carb venturi
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Topic: B Allis marvel carb venturi
    Posted: 09 Aug 2017 at 3:09pm
We have a customer in need of one .. seems the unit he bought would not run - opened the carb and discovered why...   so we are in need of a MS venturi
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2017 at 4:24pm
Steve at B&B can probably help you with that!
wfmurray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2017 at 7:06pm
I bought 49  B in bad condition  and it did not have a venture in it. Put a carb on off a C A and had to file holes to get it on What is different in C A and a B.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2017 at 7:39pm
What's the Carburetor number. Should be a little disc riveted to the side of the float bowl, or sometimes the tag is riveted on the throat of the Carb. Should be TSX-xxx and three digits. Once I know what the number is, I can probably help you out...
Steve@B&B
This page was generated in 0.069 seconds.
