converting belly mower |
corbinstein
Topic: converting belly mowerPosted: 09 Aug 2017 at 11:49am |
I've got a NFE WD that I'd like to cram a belly mower on. I've run across a Woods 60" that came off a B. Here's the Craigslist link. https://huntsville.craigslist.org/grd/d/reduced-woods-belly-mower-60/6246211409.html
any idea how to make this work?
Bill Long
Joined: 12 Sep 2009 Location: Bel Air, MD Points: 4556 |
Posted: 09 Aug 2017 at 12:13pm |
You might want to go to the Woods web site. They may have made a mounting kit for the WD and might still have some available.
Frankly, I do not recall any mountings made for the WD however, it is worth a look. They may have pictures of a mounting that may help you. Good Luck! Bill Long |
Butch(OH)
Joined: 11 Sep 2009 Location: Lucerne Ohio Points: 3842 |
Posted: 09 Aug 2017 at 12:22pm |
I would look for one that was made to have the drive pulley on the PTO shaft instead of a B/C type that runs off the belt pulley due to the idlers for the belt being different. The B/C type are left hand rotation while the PTO shaft type are right hand,, must be a reason for it.
Lance/SC
Joined: 14 Sep 2009 Location: Lexington, SC Points: 411 |
Posted: 09 Aug 2017 at 1:11pm |
HMM---------do I need to go check and see if the one took off my B when it spun a bearing is still in the shop? LOL Ya been to South Carolina lately?
Dakota Dave
Posted: 09 Aug 2017 at 5:05pm |
The woods mounting kit for a WD includes a v-belt pulley that goes on the PTO shaft. ive only seen a L306 mounted on a WD. A 60" mower is to narrow for a WD. A finish mower is one place where more power dosent make it better. itll only clear discharge so fast more power just means your going to break it before it stalls and those long belts a expensive.
