New acquisition B
Hubnut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubnut Quote  Post ReplyReply Direct Link To This Post Topic: New acquisition B
    Posted: 08 Aug 2017 at 5:58pm
I bought another B.  This one is a 1942.  I bought it from the family that purchased the tractor new.  They bought it in Gadsden,Alabama in 1942 and used it on their Dairy farm.  It has been restored in the past, but still needs a bit of work.  It's cool to be the second owner.
Edited by Hubnut - 08 Aug 2017 at 5:58pm
1940 B "Lucy"
1941 B w/ Woods L59 "Flavia"
1942 B w/ finish mower "Dick"
1941 C w/ 3-point "Maggie"
1947 C SFW w/ L306 "Trixie"
1972 314H
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2017 at 8:54pm
Awesome! Can't wait to see what you do with it!
Also...anyone know if that swinging draw bar is a very common option? I've never seen one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2017 at 7:07am
Nice B. That is a good find.
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2017 at 7:14am
They're not real rare I've seen right many over the years think I have 2 or 3 around here now.
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2017 at 10:34am
Congratulations!!!  You have another of my favorite.  Did I understand a 1942?
Take good care of it.
Good Luck!
Bill Long
ps:  Be sure you give us updates
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2017 at 6:51am
Steve,
Good to here from you! Congratulations on the new to you B! That should be a good one!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubnut Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2017 at 8:21pm
Chris and everyone.  Thank you.  It's good to be back.  This little B engine is apparently back together wrong.  I think the timing is off between the cam and crank.  I'm going to pull the front cover and pan to peek inside.  When I try to start it, it seems to be 180 degrees out.  It is trying to fire in the carb.  We'll see.  Man told me he had it rebuilt 10 years ago and it never got started again.  I think someone did something wrong.
Steve
1940 B "Lucy"
1972 314H
Ted in NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2017 at 9:13pm
Swinging hitches are not too rare but are uncommon. That one is not a  factory swinging hitch it is home made.
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2017 at 1:20pm
Getting something that has been in the same family for 75 years is special.  Looks to be a nice little B, congratulations on your new purchase.
Allis Express participant
cdon_FL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cdon_FL Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2017 at 1:37pm
But WHAT'S ITS NAME ?
Chris in NE Florida
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2017 at 5:21pm
Good point! ??????
Timing may be out 180 in distributor position??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubnut Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2017 at 6:22pm
Chris,
I've tried everything.  It's a magneto.  The flywheel matches with the compression stroke of #1, but when I crank--it only pops occasionally and through the carb.  I may mess with it one more time before pulling the engine.  One thing I did notice right away was the brass bushing for the mag drive was not even replaced.  Makes you wonder about what else was done incorrectly inside.  It might be worth the effort to peek at it.
Name?  Dunno.
1940 B "Lucy"
1972 314H
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2017 at 6:49pm
Hub one thing to look at since they worked on it is the valve rocker arm clearance, If they had the head plained or the head gasket is thinner and they didn't adjust the valves they will be to tight.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubnut Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2017 at 7:18am
Thanks B26240.  That is an excellent thought.  It also made me think that I should be able to determine if the cam and crank are in sync looking at the valve train!  I'll try that.
1940 B "Lucy"
1972 314H
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2017 at 7:54am
For some GREAT tips on the timing of the mag, send TomMN a PM.  He showed me a couple of great tips that make it almost fool proof at Hutch.  THANKS Tom Foss!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2017 at 8:21am
If you crank it by hand till you feel compression on #1, then bring that piston to the top, you can take the cap off and see where the rotor is pointing to tell if it's timed close.
 If it is, I would pull the valve cover to check clearance before I would pull the front cover and oil pan.
