K2 in oats ???
JimWenigOH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimWenigOH Quote  Post ReplyReply Direct Link To This Post Topic: K2 in oats ???
    Posted: 07 Aug 2017 at 8:42pm
    My K2 is currently set up for wheat. A neighbor has 5 acres of oats and asked me to harvest them.  I have the blank cover installed over the perforated clean seed panel. Should this cover be removed for harvesting oats? Other than closing the fan down some, the other settings listed were the same as for wheat. Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2017 at 9:12pm
No. Leave cover in for oats.    MACK
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2017 at 9:13pm
I would not...why ever remove it these days,,, sell the weed seed unless they are docking for weed seed - and if they are maybe the adjustment should be in the sprayer rather than the combine :-)
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2017 at 8:21am
We never changed much beside the fan when going from wheat to oats. If the oats are heavy they run easily, all the ones I saw grown locally were cut for hay.
WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2017 at 12:01pm
Jus check the amount of grain returning by return elevator out the right side window and operate fan accordingly.
We have a neighbour that has an A-430 head on a K2 diesel.
Fred Dunlop, G,B,CA, WC,WF, 3 WD45`s,gas, diesel and LP,U,D10 series III, D12,D14,D15 SERIES II,D17 Series IV in Gas and Diesel ,D19 GAS and D21,170 185,210 ,220 an I-600 8070 fwd, 716H and 1920H
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2017 at 6:47pm
WD45, your neighbor either only has 110 BPA corn or has an unlimited supply of tranny clutch discs IMO. Not to mention rear wheel weights
This page was generated in 0.045 seconds.
