185 power director problem
ryanschott View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ryanschott Quote  Post ReplyReply Direct Link To This Post Topic: 185 power director problem
    Posted: 07 Aug 2017 at 11:45am
My 1980 185 when shift from low to high it will it will hesitate for maybe 5 seconds and then grind for a second then go to high and be fine but does that every time. When I have it idled down and go to take off sometimes it won't until I give it move gas. Can i do something to kick up the pressure or is there a valve stuck
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2017 at 12:04pm
Won't know anything until you get a 400 psi gauge and plug it into the manifold where the brake latch mechanism is. Sounds like a stuck pressure regulator spool from your story. Should have more than 250 psi in low and high sides.
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2017 at 12:33pm
This one sounds like something in the high side of the clutch pack,
 but lets hope for his sake that it is just the valve with maybe a broken spring or a bit of dirt like the 200 had recently for me.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ryanschott Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2017 at 10:34am
I will get a gauge is there a plug I can take out to screw gauge in. And where is valve that might be stuck
