D17 Start tractor up hydraulics go up
lumaro View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lumaro Quote  Post ReplyReply Direct Link To This Post Topic: D17 Start tractor up hydraulics go up
    Posted: 07 Aug 2017 at 3:27am
Hi i have a 1964 D17 Allis The problem is  when I start the  tractor up the hyd start going up  it will keep going  full psi, it blow one on the cylinders for the bucket it will not come down.  l  I have back the down speed control all the way off also the traction  and the hyd control are not working right do I have a pump prob.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2017 at 4:43am
Check the linkages, then the pump...
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2017 at 7:21am
Sounds like a one-way loader with a trip bucket???????????? Be nice to have good information.  I'd be thinking traction booster linkage underneath the belly is bent or disconnected causing the pump (Pre-series 4) to pump all the time.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2017 at 9:42am
Yep, need to know if it is a series IV or not.  I suspect it is a linkage issue.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2017 at 3:41pm
I had my WD hydraulic lift go up and not want to come back down immediately upon start up and it turned out to be a broken spring stuck in a spool inside the pump. Similar pump to the D17 Series I, II and III. SeriesIV is different.
Edited by Lonn - 07 Aug 2017 at 3:42pm
Wink
I am a Russian Bot
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2017 at 7:14pm
Lumaro talks about loader bucket cylinder...
  ...so I think he has separate control valve for the loader and running the D17's pump through it... and the pump is pumping all the time so... I think he has either control valve unloading valve issue or the pump linkage is disconnected... or the traction booster linkage is bent, but the lift/lower control in lower position would relief the traction booster too so back to the lift/lower not functioning... just my guess.
