should I be concerned
drak View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote drak Quote  Post ReplyReply Direct Link To This Post Topic: should I be concerned
    Posted: 04 Aug 2017 at 3:13pm
Just back from a long drive with my WC and on my return there was oil leaking from the inspection plate on the underside of the clutch bell housing !!!
JimD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimD Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2017 at 3:26pm
Rear Main seal. Could be pan gasket too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2017 at 3:34pm
At least you made it back  !!
My main D-14 has both leaky fron and rear seals so if you want to 'practice', come on up ! The drips don't bother me too much...kills weeds and ols the snap coupler ring on the implement I drive up to when I park in the shed !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2017 at 4:08pm
see how many drips or quantity you leak.. put a pan or rag under it to check..  Several drips is not a problem.. Spoonfull might not be a concern. If your having to add motor oil often, then something of concern... Rear seal drips slightly... could get on clutch plates and make it "stick" sometime.......... monitor.......... not a concern.
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2017 at 4:34pm
At least you made it backĀ  !!
Well you hear something new everyday.   Hopefully your just joking.   Yes during go season you might have to add oil and go but when you buy oil by the 55 gallon drum it sort of adds up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2017 at 6:03pm
no, not joking, actually all my D-14s leak a bit. But I don't farm with them otherwise I'd tear them all apart and fix the leaks( dang PTO lever o-ring is INSIDE 'somewhere').
The blowby from the forklift was worse but I 'fixed' that. Bodged a lower rad hose( has spring in it) and ABS bits and pieces between where the oil fill cap was ..to...the custom airfilter T unit. NO more mess on the floor, easier to start too....and a lot cheaper than the 5000 Canucks I was quoted to fix it.
Jay
drak View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote drak Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2017 at 2:59am
thanks guys, drips don't bother me either, only her who must be obeyed gets narked when I carry oil into the house on the underside of my shoes !!
I was just a little concerned that it would cause an issue with the clutch !!!
Yes she went about 25 miles yesterday with no problems, I just modified her to run on Kero by adding an additional gasoline starter tank and ran fine on it ClapClapClapClap
