New to Me Moldboard
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Topic: New to Me Moldboard
    Posted: 02 Aug 2017 at 3:02pm
Just acquired a Model 50 3-bottom plow. Two of the bottoms have a moldboard that looks like the picture below. I've been through Plows 101 on the Knowledge Forum and am not able to match it to what I'm seeing there. Can anyone tell me what the proper name for this moldboard is? And the model # for the bottom as a whole? [Hope I've got the terminology right - I'm definitely not a plow expert!] Thanks!
Dave
WC, CA, D14, WD45
Dipstick In View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dipstick In Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2017 at 3:21pm
That moldboard has a funky "cover board",,,,,,, that little part that is raised above the level of the regular moldboard. The purpose of it is to take a little slice of the dirt as it comes up and to flip it over, early, which would cover trash a lot better. I have seen a lot of different styles, but that is a new one to  me!
As far as the bottom number, the moldboard should have a number stamped in it, which is that particular piece. Bottoms are made up of different styles and shapes for different situations, like sod, clay, rocky ground, and etc!
Other guys can better explain this to you, but at least you have a start!
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2017 at 3:42pm
I've seen quite a few of those shin/coverboards, although only on AC plows, never on any other color ones. However they are much rarer that the ones that mount above the shin.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2017 at 6:11am
Thanks, both of you. Clearly a little different from the plows I've seen around central Massachusetts! I'll have to go looking for numbers when time permits.
Dave
WC, CA, D14, WD45
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2017 at 11:29am
Dave,  If I recall they could well be an after market item.  I do not believe they were im the Allis Chalmers Parts book.
When we had a trash problem we used an aftermarket offset coulter, similar to the G coulterl  Worked fine.
Good Luck!
Bill Long
Edited by Bill Long - 03 Aug 2017 at 11:30am
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2017 at 1:35pm
That is a moldboard with a shin, some AC plow bottoms used shins some didn't. The leading edge of the moldboard tended to wear fast so a shin was easier to update than the whole moldboard. In my plow bottoms book I see the trash cover shin piece offered for 371, 372, 373, 374, and 375 plow bottoms. Different part number for the 375 from the rest. The 370 family bottoms are newer than a 50 plow frame, but since AC used the same plow frog mounting bolts and bolt positions for a very long time a 375 bottom could be mounted on the earlier frame. And the 375 bottom parts were made by several makers for a long time, might even still be made, I haven't looked lately.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2017 at 10:16pm
Thanks, Bill and Gerald. Appears that this plow morphed a bit over the years!
Dave
WC, CA, D14, WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2017 at 10:10am
It is possible it morphed from the beginning. I believe that ordering an AC plow took three orders. One for the plow frame, one for the hitch, and one for the bottoms. That were assembled by the dealer or the farmer. I don't think there were package orders for a complete assembly with preselected bottoms for a particular plow frame. As far as i can tell (from not being in my plow frames parts book) the 50 was an earlier product than the 60, 70, and 80 but all where made out of mostly stock steel bars bent and bolted together with similar shapes. The distinctive feature of the 50 was the vertical plow shanks where 60, 70, and 80 were slanted. 60 frames like 50 frames were fixed width. 70 and 80 had more bolt holes and pieces so they could be assembled at least a couple different bottom widths. 60 and 70  original plow shanks were shear bolt mounts. 80 came with spring trips. In the plow parts book there are kits for installing spring trip shanks on 60 and 70 plow frames. So morphing and changes were part of the plans. With the 50 being earlier than the 60, 70, and 80 its probable that the available bottoms were fewer.
Gerald J.
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2017 at 10:47am
The mould board numbers that I've mostly seen are painted on the back side, and after many years of service are rather hard to read.
Dusty
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2017 at 2:17pm
Trash coverer shin Assy for 371,372,373 bottoms part #344474, used with brace part # 340965
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2017 at 2:43pm
Allis plow bottom parts have the part number not the bottom number stamped into the metal, not huge but generally legible unless painted a dozen time.
Gerald J.
This page was generated in 0.046 seconds.
