7080 8070 7580 ect drawbar mods
cowkicker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cowkicker Quote  Post ReplyReply Direct Link To This Post Topic: 7080 8070 7580 ect drawbar mods
    Posted: 01 Aug 2017 at 8:40pm
 I sure would like to see pics of members beefed up draw bars on their 7000 and 8000 series tractors. Anyone modified theirs so it would hold more tongue weight.  Thanks
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2017 at 2:55am
I think tornado8070 made one not sure I spelled his logon right.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2017 at 7:20am
Effective in the mid-8000 series run was a drawbar of the exact same dimensions that was heat-treated and much stronger than originals. I think maybe 8070's may have always had it?? Anyway, you CANNOT tell the difference by looking at them. 90%+ of anything you find in a boneyard will be the softer design.
Post Options Post Options   Thanks (0) Thanks(0)   Quote cowkicker Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2017 at 7:52pm
I'm wanting to use a bigger heavier duty drawbar from a larger tractor. I will have to build  a heavier bracket for the rear mount.  My goal is to have a drawbar that will support 6500# tongue weight.  Is this too much to try to support, besides the 3/4 holes that hold the original rear support, I noticed that there are two 5/8  holes on each side  that could also be used to help secure a heavier support bracket.  Think this idea is realistic?
Gary(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2017 at 9:46pm
Loop a chain around 3 point arms and use the arms as extra support JD uses them for drills and other heavy drawbar applications. Run chain under drawbar with a little tension on it when raised fully.
Peterson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2017 at 9:48pm
Could one put the whole set up off a 4w305 or 8550?
7095-685I at 255hp, 8070-225HP,8050-210Hp,8030 with 155HP,220 with 670T engine with A-pump, 7580, 185 with 140HP, 2-6080's,6070, S4 D17,wd45,CA,st34 agco, S1 D17 with 3500MK2
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2017 at 10:04pm
I run top link to a heavy bracket bolted to Drawbars.   MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote cowkicker Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2017 at 10:17pm
       Don't have access to 8550 or 305 to compare. Would be a good idea though!
Post Options Post Options   Thanks (0) Thanks(0)   Quote cowkicker Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2017 at 10:19pm
Thought of that too, would you have any pics. I would also have to allow for a pto .
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2017 at 10:20pm
put a carrier wheel under the tongue of the implement. what machine are you trying to pull? did you modify it yourself that made it heavier? or is it a factory machine? maybe modify it more to hitch to a quick hitch on the 3-point
Post Options Post Options   Thanks (0) Thanks(0)   Quote cowkicker Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2017 at 3:24pm
Wanting to pull a 42ft  Schulte mower in pasture fields. After it is unfolded the front does have support wheels on the front of the wings, when in transport position  is when all the weight will be the problem. Again, just wanting to use it for light duty pasture work.
tornado8070 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tornado8070 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2017 at 6:17pm
I do have a "bra strap" made for mine to run large square balers. If someone wants to post a pic I text email it to them.
09’ DT205B, 08’ DT220A, 83' 8070 MFWD, 83’ 8070 85’ 8050 MFWD, 83' 8030, 82' 8010, 85’ 6080 MFWD, 84’ 6080, 79' 7020, 85' M3 RWD, 85' 920 diesel,AC C-50 forklift.
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2017 at 10:47pm
ya might want to see what the minimum HP required to run a 42 ft. machine,,, I'm betting its a lot more than what an 8070 can do
if ya gonna put it on a 8070 I'd sure look into some sort of 3 pt hookup to carry that kind of weight, or I think your just asking for a lot of broken drawbars...
Post Options Post Options   Thanks (0) Thanks(0)   Quote cowkicker Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2017 at 11:30pm
Yes, I am aware of the recommended hp requirements, but as I said earlier I am just going to be "clipping" pasture nothing major. I pull a 26ft now with an 8050 or 8070, just cruise around about 2/3 throttle in 4th or 5th in the powershift with those tractors. I am also sure that when I move into some heavy CRP that i will definitely need more hp but for now my main concern is keeping my pastures trimmed up!
