want be long before I will be ready to pull
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Topic: want be long before I will be ready to pull
    Posted: 19 Jun 2010 at 4:41pm
Edited by mlpankey - 19 Jun 2010 at 4:42pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2010 at 5:27pm
with hood set on it.
Carl(NWWI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Carl(NWWI) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2010 at 7:04pm
looking good. cant wait to see how she pulls
Carl
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2010 at 7:11pm
Hey, ml, good luck with your slightly modified WD!!!!!!! Enjoy.
WC, CA, D14, WD45
Allis Fields View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Fields Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2010 at 7:39pm
I didn't see the oil lines. Did you do something diferent with the oiling system?
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2010 at 7:50am
yes I am going to do something different with oil lines . I am going to run a oil cooler and turn the filter housing where i can run a performance oil filter with no check valve and bypass valve.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2010 at 7:53am
The word is,the engine has been massaged .here in TN. lol
michaelwis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote michaelwis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2010 at 8:01am
Come on man !!
IH weights ?
WD WD45 DIESEL D 14 D-15 SERIES 2 190XT TERRA TIGER ac allcrop 60   GLEANER F 6060 7040.and attachments for all Proud to be an active farmer
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2010 at 8:32am
Originally posted by michaelwis michaelwis wrote:
Come on man !!
IH weights ?
well the ones on the front are ford
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2010 at 8:34am
"massaged" - great word for it!
WC, CA, D14, WD45
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2010 at 9:28am
C'mon guys, cut him some slack-  cast iron weights were the only things that IH and Ford had that worked worth a $___
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2010 at 10:11am
Massaged means ,NOT a WD Block !!! LOL
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2010 at 12:12pm
belt drive waterpump steal too much hp?
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2010 at 6:08pm
I dont know how much power the original water pump pulls. the water passages in the block are blocked off by the massaged sleeve size.  Water will flow only through the head in the back casting plug and out the front casting plug .the reason for the oil cooler also.
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2010 at 6:09pm
When your trying to get on the cover of Hook Magazine, you can't have too much power.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2010 at 7:02pm
I was real curious if the starter would turn her over with a 12 volt battery or if the 16 volt race battery was a must . it turned over with  the 12 volt but the 16 will go on it for the 7 box the 6 box pictured will be removed.
Kip-Utah View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kip-Utah Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2010 at 12:24am
Mitch, it looks like a winner sitting still! Good luck and keep us posted on your results. Kip
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2010 at 12:47am
show us pics at the pulls!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2010 at 6:00am
Mitch, that's a tough looking machine! What do you mean by "6 box" and "7 box"? Thanks. And more pictures, please!!
WC, CA, D14, WD45
Good View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Good Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2010 at 6:57am
Can you tell us the cube? The biggest I've seen is 440 but I heard of a little more than that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2010 at 7:26am
Its 400 plus its not as big as 440. On the boxes 6 is a msd 6 al ignition box the 7 is the msd 7al2 ignition box . The 7 was to much energy for the small cap delco distributor and the 6 box wasnt enough energy for the compression ratio. So the hei distributor cap remedied that. I have heard of 500 inches but I havent seen it somethings are like fish stories they get bigger the more they are told.
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2010 at 10:41am
That tractors not for field work anymore.
  ML, Now your talkin sensible even if you are massivly massaging that engine. LOL
    Looking good, Lets see some pics in action when you fire that bad girl up on the home stretch.
 ... I see the rad shroud says WD and you have the solid block, You better have the heli trans in her, if its spur, neighbor took 3 of them out with to much ponies. The last time he dang near left the tractor when a shaft snapped and sent him flying off the seat.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2010 at 1:30pm
Field work? I like them airconditioned cabs and power steering for field work. Its a wd45d rearend.
acd21man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acd21man Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2010 at 3:47pm
where u located in tn im in warren. your thang says viola  are u from around here
Jeff(WD45-SATX-TN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff(WD45-SATX-TN) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2010 at 4:39pm
Was just about to ask that same question acd21. ML when are you gonna head out to the pulls? Would like to see the maiden voyage.
Jeff
1954 WD45 NF "Iron Tater"
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2010 at 4:53pm
I have pulled at warren county before . I should be at lawrenceburg in august . I hope not to miss it I enjoy it and usually do well there also. cleveland tn is location vols country .
Edited by mlpankey - 21 Jun 2010 at 5:07pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote acd21man Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2010 at 8:59pm
it looks like u done pretty good in the pull page
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2010 at 9:05pm
We hope we can do better
Cal View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cal Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2010 at 9:16pm
Does one lug bolt really transfer that much weight? Just kidding, looks good What are you running for fuel to burn cool enough for full pulls. Have fun. Cal in Ct.
