Hydraulic packing removal
wertach View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wertach Quote  Post ReplyReply Direct Link To This Post Topic: Hydraulic packing removal
    Posted: 01 Aug 2017 at 11:29am
I'm trying to replace the packing on my 1954 AC CA.
Anyone know of a way to get the old packing out without taking the whole cylinder off and taking it apart? I have the nut out but I can't see a way of getting the packing out.
Due to health reasons I can't get under there to remove the cylinder.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2017 at 11:59am
a "packing puller" basically looks like a screw driver with a cork screw welded on the end.. You screw it in a turn or two and PULL ......... Try screwing a drywall screw into the packing, then pulling with vice grips.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2017 at 12:01pm
Product Details
Google "packing puller" if you want to buy one on -line.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wertach Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2017 at 12:20pm
I have a rope packing puller like the one shown. Mine has a metal washer under the nut. It is too close of a fit to get anything in there.
My problem may be solved.
My neighbor came over to borrow a tool and he said he would take them off for me. He got one off and wasps came out of the other lift arm. I'm out of spray so there will be a delay while I go get some more spray. He said to call him and he would come back to help.
Thanks guys!
Post Options Post Options   Thanks (0) Thanks(0)   Quote wertach Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2017 at 12:22pm
PS The replacement packing I got from Steiner isn't packing actually. It is stacked seals. I hope it works!
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2017 at 12:33pm
That's what the packing looks like on these AC cylinders
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2017 at 12:34pm
wd40, zep, or Kroil will kill wasps quickly without a trip to town
alan-nj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote alan-nj Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2017 at 12:43pm
do a search on this site.  danny raddatz did an excellent write up on how to re-do the CA cylinders.  its probably about 2 years ago or so...
If ignorance is bliss, than happy days are here again.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wertach Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2017 at 2:01pm
I needed a lot of distance! My Kroil won't spray that far! I used degreaser it sprayed about 10 feet.
After standing it on end I was able to get the washer out. I think someone added it years ago to compress the seals more. It had rubber cup type seals, as was stated by someone above, with one fiber one on the bottom. I guess they call it packing for simplicity?
The replacements alternate one rubber the next plastic and so on. The plastic ones were very hard to get in, but I finally got them.
As soon as I'm sure the wasps are clear I'll call my neighbor back. Every time I go back to check there are 2 or 3 new arrivals.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2017 at 11:02am
Best time to get em is early morning or late evening. Use hair spray on em. it gets on their wings and they drop right down. You can get real close and not get stung.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2017 at 10:02pm
problem is wasps are not to bright.. When you spray the next, several are " out looking around".. they come back later and the nest is TOAST... They don't get the hint, they just keep coming back , hoping the nest will be there...eventually you will spray them all.
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2017 at 7:02am
I keep a spray bottle of mineral spirits that has an adjustable nozzle on it.  It's my go to tool for wasps.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2017 at 7:36pm
You do not have to worry about a wasp stinging you . . . They bite!!  Bees sting!!Big smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2017 at 9:36pm
wine cork remover tool
