Polarizing generator
Njlynch1925 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Njlynch1925 Quote  Post ReplyReply Direct Link To This Post Topic: Polarizing generator
    Posted: 31 Jul 2017 at 6:44pm
I have a 1953 Allis WD with the original 6 volt pos. Ground. It was charging until i replaced the battery. I am. Not sure how to polerize it. The Gen. has a cut out one wire going from cut out to in side the gen. The other wire from the cut out back toward the battery box then ther is only one post on the gen body back from the cut out that wire goes to the battery box as well . Any help would be great thanks
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2017 at 8:29pm
Is there a wire to F terminal on the generator? There should be. If so, touch that terminal to ground while the engine is running and see what happens. Someone will need to watch the ammeter while you do this. Do this first.  If this works, check and make sure the instrument box is well grounded. If this doesn't work then run a wire from the battery negative and tap the other end to the A terminal on the generator while the engine is not running. A momentary tap is all you need.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Njlynch1925 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2017 at 8:31pm
I am not sure which is the F or the A terminal as they ar not marked . I have two post that the cut out is attached to then one single terminal that sets back from that
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2017 at 8:51pm
Wrong. There's your problem. I don't see how it ever charged in the first place. The A terminal would go to the cutout and the F terminal should run back to the light switch. You need to sort things out. Look more closely. The gen terminals may be marked but somewhat hidden by the paint.
Edit: Are the two terminals from the generator tied to a single terminal at the cutout or are there three terminals on your "cutout?"
Edited by DougS - 31 Jul 2017 at 8:55pm
DanD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanD Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2017 at 8:57pm
There are only two wires that go to the generator.  As the other post said, from the A terminal on the generator to the cutout and then from the other post on the cutout to the ammeter.  I don't remember how the cutout is marked..maybe A and BAT?  Have to have those hooked up the right way as well.  The other wire from the generator goes to the F terminal and it goes to the resistor on the light switch.  The terminals on the generator are marked.  Like the other post said, may just be hiding under paint.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2017 at 10:19pm
Because the current in the A circuit is much larger than the F circuit usually the A circuit stud at the generator is much larger than the F stud, like 1/4 vs #8 pr #10.
Polarize the generator (also called flashing) by using a jumper wire from the Battery post of the cutout to the A post on the cutout or the generator. Do that before running the engine in case you installed the battery backwards.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2017 at 1:04pm
To polarize just jump across the cut out relay momentarily. Both posts are marked A or F. You might have to buff off the paint to find them, but they're there. Every tractor generator I've seen the posts are the same size. Do what Doug says and ground the F terminal at the generator and see if it comes alive.
Joe DeLisle View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe DeLisle Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2017 at 8:49pm
Did you hook the new battery up correctly? the WD was a positive grounded system originally. what do you currently have...positive ground, or negative ground?
Super44 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Super44 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2017 at 5:45pm
I am kind of in the same boat.  My C has not been charging because the cutout had a busted wire.  I changed the cutout and still it was not charging so I went in search of info and landed here and signed up.  After reading this thread I did the wire from the battery to the A post on the generator and Vaa Hoo it was charging---- for a while.  Then the needle started bouncing and went to discharge.  After about 10 minutes it started to charge again for a bit and then discharge.  Is this normal??  I've had the tractor for many years as it has a woods mower deck under it that gets weekly use.  I've just been putting the charger on it when I was done but I finally got tired of that dance.
Edited by Super44 - 06 Aug 2017 at 5:47pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2017 at 6:28pm
I'd speculate that the problem is in thw wire, switch or resistor in the F circuit. Probably a loose ground. Understand how the F circuit works: When the F terminal is grounded the generator puts out the maximum current. This output can be changed by adding resistance to this circuit. If you have an intermittent ground or loose connection the generator will behave as you described. This is why I told the original poster that his genny couldn't work as it was wired. The F needs to be pulled low, not high.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Super44 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2017 at 7:11pm
Not sure what "F needs to be pulled low" means.  When the tractor was running I tested the battery and got nothing.  With the tractor off I got 6.32 volts at the battery. I am very new to this kind of issue!!
Edited by Super44 - 06 Aug 2017 at 7:12pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2017 at 7:22pm
"Pulled low" is electric speak for shorted to ground. Pulled high means connected to the voltage side. These can be done through a direct wire connection or through a component such as a switch, transistor, relay or whatever.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2017 at 10:21pm
There are two ways for a manufacturer to wire a generator field, one connects one field wire to the A post and then grounds the field direct or through a resistor to control the voltage. the other connects one field wire to the generator shell to be grounded by the mounting bolts and then the regulator connects the field wire to the A wire direct or through a resistor to control the generator voltage. Generally AC used the first connection but other users of generators used the other connection.
With a working regulator the generator voltage should be 7.1 volts for a full charge. Lower means not charged, higher breaks down the water in the electrolyte requiring regular refills with distilled water.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Super44 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2017 at 7:26am
I checked all the connections and none seem to be loose.
Edited by Super44 - 07 Aug 2017 at 9:24am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2017 at 9:50am
Is the box with the ammeter and light switch grounded securely or is it only slipped into the holder?
ETA: Is the light switch itself secure in the box?
Edited by DougS - 07 Aug 2017 at 9:53am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Super44 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2017 at 2:13pm
The box was just slipped on but I cleaned it up and put in the screws.  I re flashed it but still have discharge when running it.
Edited by Super44 - 09 Aug 2017 at 2:13pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2017 at 3:42pm
Short the F terminal to ground while the engine is running. Have someone watch the ammeter while you do this. If the ammeter shows that it is charging, the problem is still somewhere in the F circuit. Possibly the light switch resistor. If it shows a bigger discharge, either the battery somehow got installed as negative ground or the ammeter got wired backwards.
As a last resort measure the voltage on both sides of the cutout. If you're measuring 7-ish volts from the generator but not out of the cutout, your cutout is bad. If your generator shows nothing to the cutout, take the generator to a shop and have it checked.
One last thing: Is the cutout grounded securely to the generator?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2017 at 8:25pm
Has the ammeter been replaced? Is it wired right? First test, turn on the ignition and lights without the engine running, it must show discharge. If not its wired backwards.
Gerald J.
