ihc 560 location to add hydrolic oil?
nickia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickia Quote  Post ReplyReply Direct Link To This Post Topic: ihc 560 location to add hydrolic oil?
    Posted: 31 Jul 2017 at 5:25pm
location to add hydrolic fluid
klaus (WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote klaus (WI) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2017 at 7:17pm
There are 2 plates on floor board that look alike on front side of platform. One is a blank plate the other has shifting stick going in it. I was told to take the blank one off (3 bolts i think) an just pour it in that way.
Carl(NWWI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Carl(NWWI) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2017 at 9:44pm
There should be 2 plugs on left side trans to add oil. Remove plug and fill. Need a flexible funnel. Fill to plug hole.
Post Options Post Options   Thanks (0) Thanks(0)   Quote klaus (WI) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2017 at 10:40pm
Ive always used top plug for a full plug. an the filter is on right side straight down from sedimentat bowl but on the right side with 6 bolts holding cover on. Cover is kinda oval shaped. Maybe 5"by8" in shape.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2017 at 12:43am
x2 with what Carl says
