185 Shifter Fork Shaft Install Question
GlenB(IA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenB(IA) Quote  Post ReplyReply Direct Link To This Post Topic: 185 Shifter Fork Shaft Install Question
    Posted: 30 Jul 2017 at 5:23pm
I am using the best parts of two shift tower assemblies to make one good one for my 185. While assembling, I have found it tough to compress the detent spring and ball while sliding in the fork shafts. Is there a special tool for this? My punch combination is not working. Thanks!
Glen
45 turboa- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 45 turboa- Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2017 at 5:32pm
I take an old intake valve like from a WD and grind a flat spot on the stem like 3/4 end up about 1/2 way threw compress the spring and ball down and slide the rail in and pull the valve out.  Works pretty good.
turbocharged
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenB(IA) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2017 at 6:43pm
Well, 45 turbo was right. I found an old punch and ground on it a bit. If I hold my mouth right, I can get the shafts in without much trouble. I guess I was just getting tired of crawling around on the shop floor looking for the detent balls when they went flying! LOL!
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2017 at 10:01pm
Use a old rail or shaft the same size, grind a tapered slot in end. Push taper over ball and spring, rotate shaft 180 degrees, push it back out with good shift rail. Makes it a piece of came.    MACK
