Thermostat 7060
jjohnso6 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jjohnso6 Quote  Post ReplyReply Direct Link To This Post Topic: Thermostat 7060
    Posted: 30 Jul 2017 at 3:05pm
Hi, is the thermostat on top, under the four bolts in the housing or is it in the block behind the thermostat housing? Thanks
LB0442 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LB0442 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2017 at 3:19pm
Both thermostats are right on top just below where the upper rad hose connects.
lowell66dart View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lowell66dart Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2017 at 3:59pm
Be ready for broken bolts if they haven't been out in a while.
AC 6080 (8030,7060,200,175,D-17HC, 6040,160,6140 all gone) Farmall 1066 & 656 Hi-Clear (for sale), White 2-62 High Clearance, JD 4255 Hi Clear.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2017 at 10:53pm
a little heat from a torch welding tip can be you friend.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2017 at 7:09am
Six bolts, not four.
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2017 at 7:23am
Strike the head of the bolt a good hard lick or two with a hammer. Do it over if you have too. This relieves the clamping force of the bolt so that all you have to deal with are the threads.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2017 at 7:36am
Smacking them is OK, but it usually takes quick torch heat right to the area of the bolt threads to get the aluminum housing to expand and let go of the bolt.
Ron(AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2017 at 1:28pm
Maybe put a bit of never seize on the bolts when installing…just for next time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2017 at 2:27pm
No maybe to it!
Post Options Post Options   Thanks (0) Thanks(0)   Quote jjohnso6 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2017 at 6:36am
Thanks for the tips to remove the thermostats. I used a little heat, hit the bolt head with a hammer and they came out with ease.
This page was generated in 0.044 seconds.
