Allis Chalmers B 12 volt conversion
Billy Ray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Billy Ray Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmers B 12 volt conversion
    Posted: 28 Jul 2017 at 10:37pm
I have purchased a 1939 Model B which had been converted to a 12 volt alternator and a solenoid controlled starter.  Having found a couple of obvious wiring mistakes causing a lot of trouble starting the tractor, I started trying to straighten it out.  Had the starter checked at a good shop, cleaned all connections, made new battery cables (old ones were really a mess), and want to put on an ammeter and key switch rather than the little twist starter button that is on it now.  What I really need now is good directions or even a diagram to help me with the correct wiring using a single wire alternator and a solenoid.  Any help will be greatly appreciated.
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2017 at 4:03am
You don't want to run the ammeter through a key switch. Most key switches are not rated for that kind of current.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2017 at 4:04am
Here is a link to Duey Shutter's website.
He has various sketches for 6 to 12 volt conversions.
Gary
http://dueyschutter.freeservers.com/cgi-bin/i/images/1_distributor_key_solenoid_start_6_to_12.jpg
