8550 Roll Call
Post Options Post Options   Thanks (0) Thanks(0)   Quote AMB(wcIL) Quote  Post ReplyReply Direct Link To This Post Topic: 8550 Roll Call
    Posted: 26 Jul 2017 at 7:45pm
Just checking to see how many are out there and whether they are still earning their keep.  I"ll go first, Dad & I just acquired serial # 1582. It has been repowered with a 282 HP Mack truck engine.  The guys that repowered it 25 years ago said it would out work and burn less fuel than the first quad-track they tried to replaced it with.  Andy
SLee(IA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SLee(IA) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2017 at 8:18am
Taken a few years ago but still working. Serial 1291
Steve
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2017 at 8:19am
A buddy of mine has one. He likes it pretty good. I think they had it overhauled about 10 years ago.
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2017 at 9:03am
We have 2 still working on the farm.  Here is my dad pictured with both and the 7580 in the back.  We overhauled the left/front one about 10 years ago.  both have cast centers and spin outs all the way around and both are less 3pt.
Edited by CAL(KS) - 27 Jul 2017 at 9:04am
aras View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote aras Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2017 at 9:12am
Beautiful!  Love the factory duals!
ACFarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACFarmer Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2017 at 9:50am
Have one here as well. Is mostly just hooked to the ripper. Don't know sn right off hand. It came from Loretta Lynn's farm down in Kentucky.
Making a living farming with and working on Allis Equipment
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2017 at 10:37am
I have one. Not sure of the serial number. Only gets used in the spring to put the crop in. Wish I had year round use for it, But I don't. It has a noble purpose and does it well I guess, so what more can I ask of it. Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2017 at 5:06pm
Darrel...see how nice they look parked inside? lol
grinder220 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote grinder220 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2017 at 7:38pm
I have serial number 1410. Repowered it with a 25000mk2 (844cu) a couple years ago after the original engine burned a piston. Huge difference in power. Hows the MACK engine pull in a tractor? I remember someone around here doing that to a 4586 IH a long time ago.
Mike Kroupa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike Kroupa Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2017 at 9:23pm
I have an early 1978 model serial #1085. Bought it in 1989 from Sandhill Equipment in Bassett, Ne. It supposedly originated from an Indian Res. in ND. It has a bullet hole through the front grill surround, don't know the story there also! Ran it hard for ten years. It has the short axles w/Mexican hat wheels and powershift rims. It is also a 3-point delete model. Replaced it with a Steiger PTA 280, 3406 Cat, which I still use today. Mike
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2017 at 9:26pm
Why did it get replaced by a Steiger? My Ford FW30 is Steiger built and I would any day rather run my 7580.
I'm assuming a 8550 is similar to operate to a 7580 just bigger.
Edited by victoryallis - 27 Jul 2017 at 9:27pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike Kroupa Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2017 at 10:46pm
It was replaced for the simple fact that the PTA 280 is just a better machine in every aspect. First is the cab, fully unitized, better HVAC system, similar to the A-C 4W series. The 3406 @ 893ci is just getting warmed up @ 300hp, the 6120T @ 731ci turned pretty hard @ 300 hp and yes mine is calibrated to 4w-305 rpm specs. In my opinion they should have used the 844 engine and would have had a lot more reliable tractor. The 750, 5 spd. Allison auto tranny is rated for 400 hp, mine has 7k hours and has never been apart. The 8550 does have closed center hyds. which is a plus if you want to run hyd. motors. I could list more, but these are just some of the major points. CIH does not support the green steigers anymore, but with places like BTP, Inland Truck,Cat, AP air, I'm able to keep it running like new. Everything on our farm is orange except this Steiger. Mike
Post Options Post Options   Thanks (0) Thanks(0)   Quote AMB(wcIL) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2017 at 10:55pm
We just got this tractor, haven't tried it out yet.  It's spent it's life working construction.  I remember it sitting at a construction company's yard with no engine in it 25 + years ago.  The contractor we got it from are die hard Mack people, they bought it with out the engine and re-powered it with the Mack back in the early 90's.  Dad and I spent the day fixing leaks and getting the cab blower fan and switch out.  Got new ones ordered.  Its not pretty by any means but it is worth saving.  Andy
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2017 at 11:50pm
up yours! !!!!!
Darrel
Post Options Post Options   Thanks (1) Thanks(1)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2017 at 2:50am
LMAO!
GM Guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GM Guy Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2017 at 11:33pm
make sure and update the registry everyone!
We dont have a 8550, but have a 4W305, its a real fixer upper project. lots of feedlot use and neglect by the previous owner. a friend east of us has a 8550 and a 4w305.
Gleaner: the properly engineered and built combine.
If you need parts for your Gleaner, we are parting out A's through L2's, so we may be able to help.
allisguy.11 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisguy.11 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2017 at 7:03am
We still run ours.. Has been retired to vertical tillage and grain cart duty.
This page was generated in 0.219 seconds.
