6080 AC
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Topic: 6080 AC
    Posted: 26 Jul 2017 at 12:21pm
Well it looks like I sold my Green tractor, decided to try to get the air conditioning working on the 6080 and try using it for brush hogging. The cold air knob clicks when I turn it on, but the compressor doesn't kick in. Does it do this when it needs Freon? Also the blower does not work on the highest setting. What would cause this? Any help or info would be appreciated.
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2017 at 1:19pm
Also could someone explain to me what the sealing gasket for the cab top should look like?
Is it still available? Someone just caulked this one on and it has leaked since I got the tractor.
ALLIS EXPRESS!
This year:
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2017 at 8:34pm
Gasket is still available from agco (reasonably priced too).  It also comes with rubber grommets for each bolt.  Stick the gasket to the top of the cab, then set the lid on top of it.
Can't help too much on your AC issues.  From what I remember reading in the manual, the AC clutched needs to be burnished occasionally.  If not it could prevent the compressor from kicking in.
Edited by DSeries4 - 26 Jul 2017 at 8:35pm
kinghunter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kinghunter Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2017 at 9:00pm
If it's Lille my 8010 if low on pressure clutch will not kick in.
wekracer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wekracer Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2017 at 9:16pm
The click you hear in the switch is it sending power to the clutch. You hear a click when it gets cool and kicks off. Most likely it is low enough on freon that the low pressure switch won't send power to the clutch.
Either one of two things needs to be done. Put a set of gauges on it and add freon and the ac starts cooling. Or the dryer came apart plugging the expansion valve and won't work. If you get a set of cheap gauges and a bottle of freon I would be happy to walk you through the process. It's really simple once you know what's going on.
Pete from IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pete from IL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2017 at 9:29pm
Agco parts books shows a low pressure cut out switch on the receiver-drier, in front of the radiator. If you have a test light you can see if the compressor is getting power. If not follow the wire back to the low pressure switch and see if there is power there. Your fan switch could be bad not allowing hi speed fan.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2017 at 9:55pm
ifn ya don't have a pricey unit to heat and force the refridgerant in,you will need to jump the plug for press switch to make compressor run and draw in gas.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2017 at 10:01pm
Thanks guys, I think I will try to find a local guy to look at it. The radiator in the cab roof looks pretty rough, I think it probably needs to be tested for leaks first off. I cleaned up the top of the cab, it isn't too bad, but the lid is really pitted. I called the local AC dealer and he said the gasket was available and around $25. I thought the coolant valve cable was stuck but I see it is ok, just not adjusted right. Hopefully I can get this thing cooling, it has been hot out here!
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2017 at 10:53pm
Yea eldon that cab without AC is bad. Can't open enough windows. Mine was not working this spring and it was the high pressure switch right there on the compresser. My neighbor does my AC for me. He made a little jumper for the wire. All it is is a ground. And got me by until I got the new switch. You can take a jumper wire to atlest see if the compressor functions. I also had trouble with the main cab plug down under lower dash. Had to put zip tie around to help hold it together.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2017 at 10:55pm
I'm hooked to brush hog to. Hope to do some tomorrow
lowell66dart View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lowell66dart Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2017 at 6:57am
I had to add a can to mine this spring. I have an 8 foot flail mower on mine right now and it's going to get a workout today if everything goes right.
AC 6080 (8030,7060,200,175,D-17HC, 6040,160,6140 all gone) Farmall 1066 & 656 Hi-Clear (for sale), White 2-62 High Clearance, JD 4255 Hi Clear.
This page was generated in 0.254 seconds.
