B allis parts ?
Wdtractorman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wdtractorman Quote  Post ReplyReply Direct Link To This Post Topic: B allis parts ?
    Posted: 24 Jul 2017 at 10:51am
I though i had a pretty good handle on this but i just talk to a guy that said i was wrong. I though you could take the stub axle out of a b with the 5 lug rear wheels and put them in a standard b. Im talking about just the axle shaft its self, i guess im trying to say that all the b rear finele drives are the same. But i just talk to a guy that said id have to change the whole thing. So am i right or him? I just want to make sure so i dont buy just the stub axle and cant use it.
rpropst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rpropst Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2017 at 5:57pm
You can exchange axle stubs on a B. The ones in a C are longer.
1950 snap coupler B 1948 WD 1951Ca 1952B 1952adjustable axel B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wdtractorman Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2017 at 8:35pm
OK that what I though. That guy was wanting to sell me the whole final drive. My b is having trouble with loose rear wheel. I'm having to retighten it about ever other time I mow, do I figure it a good time to swich sence I was wanting to anyway. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2017 at 8:51pm
check you HUB splines if you go that route... I normally see a LOT more wear in the cast hub compared to the steel shaft splines......... but if you go with the 5 bolt, you wont have that problem....... do you drill the old hub or buy new ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wdtractorman Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2017 at 9:18pm
Steve, are you talking about the adapter hubs they made?
