positive /negative ground?
grinder220 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote grinder220 Quote  Post ReplyReply Direct Link To This Post Topic: positive /negative ground?
    Posted: 13 Jul 2017 at 7:28pm
Bought a D17 last week that has been sitting in a shed for 20 years or better. It didn't have a battery in it. How can tell if the ground has been reversed? Going by the ground cable post size it has a negative ground.
tomNE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tomNE Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2017 at 7:49pm
it'll be a good bet, if it has a generator that is a positive ground.
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2017 at 7:51pm
The better battery cables I'm familiar with wouldn't allow the positive connector to fit on the negative post. Cheaper cables have the connectors sized alike. In any case it probably won't matter how you install the battery, polarity wise. At least it shouldn't hurt anything, providing the tractor doesn't have an alternator.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2017 at 8:44pm
Look at how the coil is connected. + connected to ign switch = neg ground. Neg connected to ign switch = pos ground. Originally all of A-C's generators were positive ground.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2017 at 8:45pm
One more thing, polarize the generator before you do start it...
Post Options Post Options   Thanks (0) Thanks(0)   Quote grinder220 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2017 at 9:16pm
Thanks for the information.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2017 at 10:15am
Another check a bit harder to do is the ammeter polarity. With negative ground the negative terminal of the ammeter goes to the battery, and positive terminal to the charger and loads. With a battery connected turn on the lights, ammeter must show discharge current if connected to match the battery polarity.
Flashing the generator after sitting a long time and with the battery polarity in question is important. Just sitting a long time can loose the residual magnetism in the field poles that sets the polarity that the generator build's voltage.
Gerald J.
