210 leaking injector lline
fastallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fastallis Quote  Post ReplyReply Direct Link To This Post Topic: 210 leaking injector lline
    Posted: 13 Jul 2017 at 6:44pm
I have fuel coming out between the nut and the line. So I put a new sleeve on the line. Still have it coming out. The tighter I get the nut more it leaks. What do I do now? It is injector #3.
210Postin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 210Postin Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2017 at 8:50pm
Well my guess is that no crush on sleeve ,back nut off check sleeve tighten again if no luck send to Scheid Diesel and have them make you a new one
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2017 at 9:22pm
Did you cut enough off line to get past the crack? Did you put new sleeve on with long taper to injector?      MACK
allisrutledge View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisrutledge Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2017 at 7:42am
Crack in nut?
Post Options Post Options   Thanks (0) Thanks(0)   Quote fastallis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2017 at 4:29pm
Finally got time to get back to it. The line was cracked just behind the ferral. I finished breaking it off. Put an new ferral on and it is good to go.
This page was generated in 0.043 seconds.
