7040 PD troubles
Lynn TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn TN Quote  Post ReplyReply Direct Link To This Post Topic: 7040 PD troubles
    Posted: 12 Jul 2017 at 7:49am
Been bushhogging with our 7040 when you load the tractor either by being in thick weeds or going up hill the PTO will slow way down then the ground speed will nearly stop as well. When you stop and let it clean out it will go again fine. Filters are good as well as both sections full of oil. Didn't know if it's a pump problem or what. Tractor has 7000 hours but hate to junk it still looks and runs good.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2017 at 7:57am
Sounds like torque limiter on the flywheel.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn TN Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2017 at 8:16am
Meant to also say transmission pressure above 1800 light stays on till pretty much wide open as well and back on when it slips.
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2017 at 8:58am
No need to junk it, if it is the Torque limiter, you just need to split the tractor and replace it, just like the dry engine clutch of old.  You will likely need to take a hard look at your flywheel, and the pressure plate, if it has been slipping like that for long, likely it is shot from heat stress.
Still in use:
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2017 at 9:52pm
Have flywheel resurfaced, new disc, and new pressure plate. Never mix old with new parts in a torque limiter.     MACK
