D17 IV timing problem?
gerkendave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gerkendave Quote  Post ReplyReply Direct Link To This Post Topic: D17 IV timing problem?
    Posted: 09 Jul 2017 at 7:24pm
Ok guys got the PTO lever fixed. Changed the plugs and let the cylinders soak in sea foam over night. The smoke problem I had seemed to go away. Father in-law wanted some small squares done for his land lord so I hooked the 17 to the NH 269 and headed his way. It's right at an hour drive with the tractor and the thing ran like a top. I think my carb is a little rich as it puffs black smoke when throttled up fast or pulling up a big hill. Get to his house and went to shut it off and the thing diesels like crazy, leading to a puff of smoke out of the intake. What am I looking at now? Timing issue? Carb issue? Valve issue? Needing guidance please.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2017 at 8:22pm
Carb is set too rich.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gerkendave Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2017 at 8:24pm
Could that be the sole cause of the dieseling?
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2017 at 8:37pm
Dieseling from carbon deposits because the carb is too rich.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gerkendave Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2017 at 8:54pm
Thanks guys. I'm not in any way a carb expert. What's the best way to adjust? And do I need to be adjusting the power screw on the bottom or idle screw in top?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2017 at 9:51pm
Have you checked the air intake, including the air cleaner? The float level could be set too high on the carb as well. I'd buy a carb overhaul kit if the air cleaner and hose are ok.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2017 at 9:52pm
Timing is too fast. 25 degrees wide open.   MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote gerkendave Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2017 at 10:00pm
Thanks gentleman. I'll check that filter in the a.m. I'm assuming the flywheel has timing marks in it?
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2017 at 7:32am
That happens when the idle is too high on some motors.  Not sure on yours.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gerkendave Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2017 at 7:56am
Thanks Dave. I'm waiting on a track cable so I'm not positive where the idle is for sure but it sounds really slow. I can try backing it down a touch more
