7030 alternator
Aaron(IN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Aaron(IN) Quote  Post ReplyReply Direct Link To This Post Topic: 7030 alternator
    Posted: 01 Jul 2017 at 6:12am
Been working on the 7030. I am looking for a Delco 10SI type 116 alternator that has the terminal block with 1,2, and R together. I bought one off of the internet, but had R as a separate stud off to the side. Any source or part numbers would be appreciated.
Thanks,
Aaron(IN)
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2017 at 6:53am
I've never seen a 10SI wired that way.
badjeep View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote badjeep Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2017 at 12:50pm
Db Electrical has a good selection, i have bought several 3 wire delcos from them and have had pretty good luck.
In the shed- 7020,7060, L2 X (2), CII, WD X (2), 200, 210, 611H, 440, Fiat Allis 345B
fourthgeneration View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fourthgeneration Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2017 at 2:26pm
I'm pretty sure you have a 12si. 10si has a stamped steel fan and the 12si has a metal and plastic fan. Edited: I should have reread what you posted. I have an 10si with three prong plug. It came from shoup parts. It is a delco reproduction.
Edited by fourthgeneration - 01 Jul 2017 at 2:51pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote fourthgeneration Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2017 at 2:28pm
Shoup sells alternators for that model that are delco style to replace the Neihoff. If I replace another one it will be a cs130. Edit: cs130 produces more amps at lower rpm.
Edited by fourthgeneration - 01 Jul 2017 at 2:52pm
This page was generated in 0.050 seconds.
