WD hard start/poor response
grinder220 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote grinder220 Quote  Post ReplyReply Direct Link To This Post Topic: WD hard start/poor response
    Posted: 30 Jun 2017 at 1:22pm
Here's the deal,I have a 1950 model, still has a mag and ran extremely good up till last summer while raking hay. It would cut out and then die while idling and then was real hard to get started. If the RPMs where up it ran fine. As time went on it got to the point if you let the clutch out and the governor opened up it would cut out and possibly die. I took off carb and cleaned it out and put a kit in it which didn't help. Next checked mag,coil had a crack so I took it off and replaced it. Lined up the "F"fire mark on compression stroke and the mark on mag to number 1. Now it would only start if throttle lever was all the way in closed position and it took several tries,it would pop but didn't really want to take off, you had to time it just right and open the throttle after initial pop and hopefully it would come alive. It still had the hesitation when the governor would open up if you dumped the clutch or what not and now I can't get it to pop at all. As soon as you start cranking it over it starts smoking out the exhaust Like its flooded. Open the throttle while cranking and smoke goes away, close it and smoke comes back. Ive tried starting it with gas shut off but put enough in the carb that it should starts and have the same results. I play with it once and a while when I'm at the farm but this has been going on for a year now so I'm looking for some advice. It was over the winter I pulled the mag and early this spring when it just would start.
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2017 at 2:13pm
First I would do is pull the rubber hose that connects the carb to the air cleaner to be sure it's not full of fuel and flooded from the float valve never shutting off the gas.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Post Options Post Options   Thanks (0) Thanks(0)   Quote grinder220 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2017 at 8:24pm
Ive done that, even put a carb from another WD on it. Didn't help.
dawntreader74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2017 at 8:44pm
the fuel is not blocked up at the tank' is it ? wear the bowl goe's in the tank
Post Options Post Options   Thanks (0) Thanks(0)   Quote grinder220 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2017 at 8:50pm
Nope,you can take the fuel line off the carb and it runs out, I drained a gallon out just to make sure it wasnt vapor locking. I'm wondering if I'm not 1 tooth off with the mags rotor. The marks are gone.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2017 at 8:59pm
if it's getting fuel' like you say' it sure maybe out of time. get #1 top dead center see wear it' fires thank it's 1243
Post Options Post Options   Thanks (0) Thanks(0)   Quote grinder220 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2017 at 9:15pm
I had planned on putting a timing light on it but now that it won't start that won't do me any good.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2017 at 5:46pm
From what you have already tried, the first thing I would do is make sure you have good spark. Have you tried removing the spark plugs, grounding one and turning it over to see if you have good spark?
While we re talking about spark plugs, are they Champion? If they are, that might be your problem. Try Autolite 295 plugs or AC Delco (I believe the AC Delco # is 42XL).
If you determine you have good spark, try removing the hose to the air filter and giving it a shot of gas or starting fluid to see of it fires. If you have good spark and it won't fire with gas or starting fluid, something is out of time (either the gears inside your mag or the mag itself.
Edited by WF owner - 02 Jul 2017 at 5:47pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2017 at 5:51pm
Here's a link that may help if your problem is in the mag.
Post Options Post Options   Thanks (0) Thanks(0)   Quote grinder220 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2017 at 11:29am
It has autolite plugs and good spark. I think ive tried starting fluid,ive been tinkering with it off and on for so long I'm not sure what all ive tried anymore. I'll double check mag timing. And I got the package the other day,thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2017 at 11:38am
I recently went through the same thing with my 39 non-electric B with a WICO mag, which meant using the crank or towing it. It would fire and run when towing it, but as soon as I pushed the clutch, it would quit. The mag timing (inside the mag) was off.
pumpkinman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pumpkinman Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2017 at 11:13pm
DON"T USE THE FIRE MARK . USE THE CENTER MARK , SET THE MAG UP POINTS OPEN
ROTOR SET ON # 1  SHOULD FIRE UP IF NOT YOU MAYBE 180* OUT OF TIME
        KENT
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2017 at 7:52am
I am not a mag guy, but this sounds a lot like timing to me. You have gas, you have spark, and you must have compression. And sounds like it did run, but not so good. So I would guess that it is the timing also. Good guy to contact is DonMO. He could talk you through it setting up the mag timing. I guess you could have a bad mag too. They are rebuild-able and several guys are able to do that. When I switched from Mag to Distributor on the last WD, I had the mag apart. Had it tested to be a hot (good spark) mag. But chose to put the money into setting up a distributor instead. Parts for the mag would have been $150 or so.
Good luck in finding and resolving your WD issues.
I haven't regretted moving away from the mag. I know they work great when they work, we used them for years. I just like the distributor better.
This page was generated in 0.270 seconds.
