Crankshaft damper
randy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote randy Quote  Post ReplyReply Direct Link To This Post Topic: Crankshaft damper
    Posted: 28 Jun 2017 at 8:48pm
Does anyone know if a viscus damper off an 8070 will work on a 8050? A 8050 has a rubber damper on it. I have a viscus damper with a pulley off a 8070 i would like to use. Thanks, Randy
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2017 at 9:02pm
Not a good idea to put a used fluid damper on another engine. If would be locked up on inside, it could do damage to engine. Not a cheap idem to buy new.
Some of the newer AGCO engines use a bigger one that cost less that could be adapted to your 8070 hub.     MACK
This page was generated in 1.836 seconds.
