Choke rod to carb connector
Scott B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Scott B Quote  Post ReplyReply Direct Link To This Post Topic: Choke rod to carb connector
    Posted: 28 Jun 2017 at 3:48pm
Anyone know where I can get one of those little brass connectors that connect the choke rod to a marvel scheduler carb? It's about a 3/8ish square block with a hole drilled through for the rod and then a threaded hole for a stop screw. Haven't found in hardware stores
D17 Series 1
Allis B- 1939
Allis B- 1945
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2017 at 4:02pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Scott B Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2017 at 5:41pm
http://www.ebay.com/itm/like/291965545271
Thanks! $10 bucks whew.....
D17 Series 1
Allis B- 1939
Allis B- 1945
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2017 at 6:12pm
But hey free shipping!
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2017 at 6:23pm
That block is for a choke cable. The choke rod was bent at the end with a cotter pin.
Not sure what tractor you need it for.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Scott B Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2017 at 10:26pm
Thanks Joe. It's for a B. The choke rod is straight.....bending it would be a quick fix and I've seen them that way before. Kind of po'd at myself for losing that block....I actually think I put it somewhere for safe keeping!
D17 Series 1
Allis B- 1939
Allis B- 1945
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2017 at 6:41am
Got a drill press?  Simple enough to make one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2017 at 9:20am
Boy, I don't know how many times I've done that. Put somethin' somewhere where I wouldn't loose it and not remember where I put it! The older I get, the more my memory is like a leaky roof! Sheesh!  We have those blocks to if interested. Ours is a lot cheaper than $10. bucks....
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Scott B Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2017 at 1:19pm
Steve@B&B
Ugh, yesterday evening I was walking through the hardware store and my light bulb came on and thought "I bet ole Steve in NJ has those things!"  I already bought the ebayer one for the $10....oh well.  But now I know for next time I lose it!
D17 Series 1
Allis B- 1939
Allis B- 1945
