2035 waterpump
psheridan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote psheridan Quote  Post ReplyReply Direct Link To This Post Topic: 2035 waterpump
    Posted: 26 Jun 2017 at 9:29pm
other than a punch and hammer, what wrench does a person use to tighten or loosen  the brass collars on each side of the water pump
One of mine came loose very easily and the other looks to be much more tight and is a SOB.
I placed Blaster penetrating fluid on it tonight and will try again tomorrow evening.
I envision a large old wrench that would engage the large brass nut.
mine are so beat up that I am afraid that a wrench, even if it is the correct wrench would not fit.
what packing material does a person use.  ( i know , I should check with Norm's antiques)
getting close to getting the old girl started
Paul
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2017 at 9:47pm
It sounds to me like you need a spanner wrench. Not sure what the packing nut looks like on a 20-35 but if it is round and has notches, a spanner wrench is the proper tool.
Post Options Post Options   Thanks (0) Thanks(0)   Quote psheridan Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2017 at 9:57pm
Thank you for your advice on the spanner wrench
I went to ebay and there are all kinds of wrenches new and old
looks like that is what I need
I wonder what size a spanner wrench I need   2 1/2?
Paul
Norm Meinert View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Norm Meinert Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2017 at 10:07pm
there are left and right threads on that pump. turn the second nut the same direction as the first to loosen. I have the wrench for sale as well as the packing. also have new water pump shaft, impeller, and gaskets.
Post Options Post Options   Thanks (0) Thanks(0)   Quote psheridan Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2017 at 6:12am
Thanks Norm
Ill send you an order
thanks
Paul
