F2 charging and chopper knife ??
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Topic: F2 charging and chopper knife ??
    Posted: 25 Jun 2017 at 5:39pm
Dad has owned this F2 for 9 years and has always had a charging issue. After 5-6 hours of operation,the battery gauge falls from the upper green to finally the upper red of lower end of gauge. Alternator was rebuilt last fall by a reputable shop and helped for a day. I personally have blown the alternator out with air(was amazed how much crap came out) yet the declining voltage persists. Pretty sure gauge is accurate because after dark,with lights on(work and headlights both)gauge drops faster and the lights get dimmer. On a side note,does any one have experience with Shoup's chopper knives? Ours have already been turned over and are very rounded on the ends. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2017 at 10:03pm
I'd bet wire connection issues on the charging. My F2 had some wires that wire no longer making good contact in the factory crimped ends. Too much resistance,getting hot and killing fuses.Think I got my knives at AGCO.Shoup's are probably just as good...these days.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2017 at 10:31pm
Check all connections from alternator to solenoid on console door. If all is good, replace solenoid on console door.     MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2017 at 7:03am
Thanks, I have noticed that solenoid gets kinda warm, can feel the heat on outside of door while turning the latches
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2017 at 9:18am
You may have missed the solenoid issue a few months ago. When you replace the solenoid be sure it is rated for continuous duty. It will cost more, but don't be tempted to go cheap with this part.
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2017 at 6:41pm
Thanks for all the input. I priced a OEM at local dealership that has it in stock,OUCH!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2017 at 7:00pm
Yup. You can try an auto parts store and ask for a 50 or 80 AMP continuous duty relay and see how they price it. Take the old one in so you can get one with the same frame. A true continuous duty relay will not get hot after hours of use. This issue came up in here last fall. Someone along the line there bought a cheaper non-continuous duty part and the problem persisted.
Edited by DougS - 26 Jun 2017 at 7:04pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2017 at 7:32pm
Thanks for the input Doug.Probably best to pay "some" now than a"bunch"later
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2017 at 9:34pm
If I remember right, mcMastercar has some that is rated higher than AGCO. AGCO used one just big enough to get by.   MACK
This page was generated in 0.062 seconds.
