D17 IV PTO
gerkendave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gerkendave Quote  Post ReplyReply Direct Link To This Post Topic: D17 IV PTO
    Posted: 18 Jun 2017 at 7:44pm
Hey everyone! Finally settled on a d17 IV. Tractor runs great but it does have a couple problems. First up is the PTO lever is broken off the shaft. If I were to buy a new shaft and oring is it possible to replace without splitting the tractor? The parts breakdown on the Agco parts book doesn't show too many pieces looks like if I could get someone to hold the internals in place I could slide the shaft out and then put the new one back in. Is this possible? The other problem is it flood easily. Once flooded it takes a ton of cranking to get it to fire. Once running it runs super smooth. Any ideas?
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2017 at 8:25pm
Regarding the PTO lever, believe it or not, it would be much easier to split the tractor to install the new lever/shaft.  Yes, it takes time to split, but it is not hard.  You will need to knock out the roll pin which holds the old shaft in place.  Before that pin comes out, you will need something/someone to hold the detent assembly in place.  If not, your job just got harder.  Without splitting the tractor, you might as well start humming the theme to Mission Impossible as the detent assembly is very hard to reach through the inspection cover.
About the flooding, it sounds like you just need to tweek your carb.  Since you just got the tractor, I would recommend giving it a good cleaning out first (in addition to the gas tank).
Good luck.  The Series IV is the D17 to have.  I have a gas and diesel, love them both.
DON G View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote DON G Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2017 at 8:31pm
If there is some shaft still sticking out it can be welded back on. If lever is lost make one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2017 at 8:35pm
Yes it can be welded, but the heat would destroy the O ring causing oil to constantly leak from that location.  So you would end up having to split the tractor to replace the O ring anyway.
Josh(NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh(NE) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2017 at 10:33pm
Allis Express
'65 190XT, 37 B, '72 170, '83 8030, and the IH 560 was a mistake
Stan R View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan R Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2017 at 5:12am
Our lever broke on our D17 IV about 20 years ago and it was welded in place. O-ring just started to leak a couple years ago and we split the tractor to replace the o-ring. Not difficult to split and fix.
Edited by Stan R - 19 Jun 2017 at 6:00am
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2017 at 7:01am
Any way to drill the center of the shaft that's still there and thread it? Also brazing
would create less heat on the shaft than electric welding if you went that route.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gerkendave Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2017 at 5:21pm
Finally had time today to tackle the PTO lever on the 17. All I can say is what a pain in the a**!!! BUT... I did get it done without splitting the tractor, that solid drive pin was a real B to get out though! Had the wife's​ help pulling the remains of the old shaft out and sliding the new assembly in. Works like a champ now! Thanks for the tips and tricks!
This page was generated in 0.139 seconds.
