Gleaner g wheat settings
spencefarm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote spencefarm Quote  Post ReplyReply Direct Link To This Post Topic: Gleaner g wheat settings
    Posted: 15 Jun 2017 at 9:42pm
So I'm getting my g ready to combine some wheat and rye. I'm trying to see if you guys have any advice on the best settings to use? What size cylinder pulley would you recommend? And any other suggestions from you guys would be great! I'm just really used to my allcrop 60 and it's way different than the g....
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2017 at 10:08pm
Pick up an operators manual for that ser number.You'll be glad you did.They are very well written and the settings are close to right.Some tweaking required for "perfection". Think my A2 said 1100-1300rpm for wheat.Had chain drive cyl,used a small sprocket.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2017 at 7:27am
Cylinder pulley, smallest 1200 RPMs. Cylinder clearance 1/4, 5 concave. Air wide open or near so. Top sieve 5/8 to 3/4, bottom 1/4 to 5/16.    MACK
tomNE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tomNE Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2017 at 8:32am
i agree with mack; i will also add; don't trust the little gauges on the outside.   open the trap door and measure the opening.   i used a piece of wood, the same width as what i needed and brought cylinder down to that.    then set you outside gauges!
wfmurray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2017 at 10:50am
When my dad got a model 60 a man told him to set cyl bars distance of thickness of a 20 penny nail. Threshed for many year and had real clean wheat.
