8030 Flasher blows main light fuse |
Post Reply ![]() |
JVan93 ![]() Bronze Level ![]() Joined: 28 Apr 2014 Location: Mt Vernon, Wa Points: 16 |
![]() ![]() ![]() ![]() ![]() Posted: 14 Jun 2017 at 7:28pm |
Ok, now I have a electrical question relating the flasher on this 8030 s/n 1020. I found that the original flasher/turn signal unit had taken a crap and you had to tap on it to get anything to work at all. I had just assumed that another similar unit would just drop in and a away I would go.... Well the main power fuse blows everytime I run the switch to the right. The left turn and 4 ways work just fine. I have done some studying and I have discovered that there is a flasher update kit that is available...? Can I get this thru AGCO or does anyone have a suggestion?
Thanks John |
Lynn Marshall ![]() Orange Level Access ![]() ![]() Joined: 13 Sep 2009 Location: Dana, Iowa Points: 2403 |
Look at the wires where they plug into the back of the switch.
You need to cut the black wire where it comes out of the harness. That was a ground for the original switch. Connect the black wire to the dark blue wire with one of those blue scotch lock squeeze connectors. |
Excellent, I'll give that a try. Thanks
John |
That worked perfect. Very much appreciated.
Post Reply ![]() |
