Allis Chalmers 7020 Tachometer Not working
Basehorhawk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Basehorhawk Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmers 7020 Tachometer Not working
    Posted: 12 Jun 2017 at 8:21am
Hello all, on top of my PTO issues with my tractor (1978 Allis Chalmers 7020, around 5700 hours), my tachometer quit showing me RPM's. Will only show around 500-750 even when i'm up around 2500 or so.
Any idea's or questions I can answer that may help you all diagnose?
Mrgoodwrench View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mrgoodwrench Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2017 at 8:27am
Check the wires at your alternator. That tach is run by the alternator . Ours has a delco on it and the third wire is for the tach.
Edited by Mrgoodwrench - 12 Jun 2017 at 2:43pm
There are 3 ways to do job GOOD, FAST, CHEAP. YOU MAY CHOOSE 2. If its FAST & CHEAP it won't be GOOD, if it's GOOD & CHEAP it won't be FAST, and if its GOOD & FAST it won't be CHEAP!!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Basehorhawk Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2017 at 8:39am
I will. Thank you very much.
This Forum is priceless.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2017 at 10:11pm
Tighten fan belts. Belts are slipping.   MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Basehorhawk Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2017 at 3:33pm
Tightened up the belts. Had a little squeal at times before I snugged them up, which that resolved, but the Tach still will only go up to around 500 RPM. Looked at the wiring and everything looked ok.
Any other suggestions? Could this possibly be related to my PTO issues i'm having from the 7020 PTO/Diff lock problems thread?
Running out of ideas on the old gal.
charlesbendal View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote charlesbendal Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2017 at 6:14am
Did you just visually inspect the wiring or did you clean the connections?
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2017 at 6:36am
Considering that the tach needle never moves I'd discount the problem as being a loose belt. It could be a loose wire, but I'm inclined to think the problem is the tach itself.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Basehorhawk Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2017 at 9:57am
To clarify, it will move up to about 500 RPM when I throttle up but I know I'm getting to around 2500 RPM, tach just doesn't climb that high.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2017 at 10:17am
Okay.  Did you change the alternator recently?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Basehorhawk Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2017 at 10:49am
Nosir. It's not original to the tractor but was on it when I bought it.
