8000 series PS or PD best for loader work?
JayD-17(NY) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JayD-17(NY) Quote  Post ReplyReply Direct Link To This Post Topic: 8000 series PS or PD best for loader work?
    Posted: 08 Jun 2017 at 9:28am
Handiest transmission to have on a 8000 series Allis if putting a loader on the tractor, power director or power shift? Thoughts, opinions, experiences?
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2017 at 9:45am
I have a loader on a PS 8010, biggest thing I don't like is hi reverse is to fast, low range is really slow, and its hard to 'feather' the clutch/inching pedal when stacking large square bales. Can't say anything for the PD trans...
jiminnd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2017 at 11:07am
I think PS would be handier for shifting, PD sometimes shift hard if not adjusted just right.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2017 at 12:06pm
7040 Power Director floor shift. Right hand runs the hydraulics and left hand does the shifting.
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2017 at 12:18pm
ill second the maroon belly floor shift.  We have one we use for occasional work isnt too bad.  would be miserable with black belly T handle
oops  not 8000 series  lol
Edited by CAL(KS) - 08 Jun 2017 at 12:24pm
bigal121892 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigal121892 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2017 at 7:10pm
Powershift
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2017 at 8:17pm
Not an 8010 PS and especially not an 8010 PS-FWA. Not enough engine for backing up at part throttle all the time in my opinion.
tomNE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tomNE Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2017 at 10:42pm
i had a loader on both my 7020 PD and PS.  no comparing, really!   PS everyday.   i better rethink my FWA loader tractor.   my loader would fit a 8010 FWA and had thought about it.  maybe i'll just retire.   as far as AC PS ground speeds go; someone wasn't thinking the day, they made those decisions.
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2017 at 11:21pm
7045 PS runs my loader. You will never ever grind a gear with a PS. Don't think you can say that about a PD. Both of our 8070's have diff. lock front axles. They would not lend well to a loader while in reverse and trying to turn.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2017 at 1:04pm
Never used a PS but always heard what Tom says to be the down side.Get along fine with my PD.Pick your ground speed.Only going to or from field is when it's not so handy.
GM Guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GM Guy Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2017 at 6:09pm
I vote put a set of Black Belly steps on a 7000 series maroon belly PD tractor. I love the stick in the floor for yard use.
Gleaner: the properly engineered and built combine.
If you need parts for your Gleaner, we are parting out A's through L2's, so we may be able to help.
Ron(AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2017 at 8:23pm
Definitely powershift.   Put 20.8x38 on the rear and 11.00x16 multi rib on front. Then install a foot throttle and stay on dry land!   Or frozen! Anything in-between and you'll go down like a rock. It's very good as a haying tractor and will pull a freight train load of hay down the road. I normally haul 19-21 round bales on a two wagon setup.
