190 Gas-Prone to head cracking?
nowaktj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nowaktj Quote  Post ReplyReply Direct Link To This Post Topic: 190 Gas-Prone to head cracking?
    Posted: 07 Jun 2017 at 5:27am
Hi guys-I picked up a 190 over the weekend that is in a basket.
I was looking at the head and it appears to have cracks in the vicinity of the spark plug pocket to the valve seat areas.
Are these heads prone to cracking?   Are they typically repairable?
Also, a quick check showed that it was out of flat by 0.009.   Is that typical too?
I have it at a cylinder head shop so I will have to wait and see what the magnflux results are.
Thanks in advance for the help,
Terry
D19D, D17D, WD, WC, Snobee, #83 Plow, SC Blade, 14' disk, 400 series planter, B , Terra Tiger, M Dozer w/Baker Blade, TL-12, 42S Grader, G
dave63 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave63 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2017 at 8:38pm
Sounds like it got run hot.
The universal answer to all questions is yes, how much do you want to spend?
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2017 at 5:56am
Not too many gassers around but I never heard of any kind of head problems. Broken pistons in the early models, yes, and the early models used a Holley carb which is supposedly junk. Dad had an XT with 301 gas and other than it just plain wore out he never had issues with it. It was a great starting tractor in the winter time.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote nowaktj Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2017 at 11:12am
Thanks guys...I think I have another head that I will try instead of fixing this one.    And...once running I will watch to see if I have a cooling problem for some reason.
Edited by nowaktj - 08 Jun 2017 at 11:13am
